| jim_hoyland |
Aug 20 2009, 09:34 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,030 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
I have an intermittant relay installed. I continue to get mystery wipes when makiing a sharp turn--not always, just occasionally. These mystery wipes seem to always occur when the windshield has just enough grime to really mess up the view.
OK: Could I be grounding the wiper switch when turning the wheel, or does the intermittant relay just go bonkers and give free wipes at its descetion ? (IMG:style_emoticons/default/confused24.gif) Who's figured this out ? |
| Kirmizi |
Aug 20 2009, 09:46 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Pull the center hub and check your contacts/wires for the wiper switch.
I had the same problem with mine and it was a loose wire closing the circuit when I turned the steering wheel. Mike |
| jim_hoyland |
Aug 20 2009, 09:58 PM
Pull the center hub and check your contacts/wires for the wiper switch. I had the same problem with mine and it was a loose wire closing the circuit when I turned the steering wheel. Mike I was thinking that is a strong possibility ; when you say loose wire, which end are you refering to ? |
jim_hoyland Mystery Wipe Aug 20 2009, 09:34 PM
Kirmizi Hell, now that I think about it, the wipers could... Aug 20 2009, 11:28 PM
ClayPerrine It could also be in the wiper motor. There is a c... Aug 21 2009, 10:32 AM
jim_hoyland Update: I replaced the relay several months ago an... Jun 27 2012, 06:57 PM
76-914 Thx for the tip, good to know. Jun 27 2012, 07:13 PM
scotty b
I was relieved t... Jun 27 2012, 07:23 PM
monkeyboy
I was relieved ... Jun 27 2012, 09:47 PM
Bartlett 914 Your problem is a loose ground connection. This co... Jun 28 2012, 08:16 AM
Bartlett 914 Here is the backside of the switch. You can see th... Jun 28 2012, 08:21 AM
jim_hoyland
Here is the backside of the switch. You can see t... Nov 21 2025, 02:25 PM
jim_hoyland Follow up:
Read a post that recommended tightening... Nov 14 2025, 07:49 PM
914Sixer Nothing comes to mind right off Nov 16 2025, 08:25 AM
jim_hoyland Next: gonna check that ground on the back of the w... Nov 16 2025, 03:17 PM
jim_hoyland See post 10 and 11….
@bob164 Nov 17 2025, 07:01 PM
Front yard mechanic If you ask chat gpt what mystery wipe is Jim’s n... Nov 21 2025, 09:32 PM
914Sixer Sending Jim a different wiper switch to play with. Nov 22 2025, 10:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th March 2026 - 12:29 AM |
