Sand Blasters, what to do?what to do? |
JimmyG |
Aug 24 2009, 04:07 PM
Member Group: Members Posts: 146 Joined: 10-September 04 From: Birmingham, AL Member No.: 2,730 Region Association: South East States |
Hello All,
Trying to get prepared to finish all of the reinforcement work on the body and decided that it would be a good idea to do a little sand blasting to clean things up a bit. I've seen units from $199 - $3000. And visually can't see any difference in them. I've seen blast media from sand to walnut shells to soda. Can somebody that has used these on a car tell me what is the best buy for a poor homeowner that wants to have a unit to use more than once but doesn't want to spend the motherlode. and the best overall media. Any help would be appreciated. Off to ball practicefor my kids. Be back to look at this in a bit. Thanks. |
trojanhorsepower |
Aug 24 2009, 10:01 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
I have tried lots of low end blasting and nothing seems to actually work well. The big problem (other than the ones already mentioned) is moisture. If you live in a humid environment and you do not have an air drier and a good compressed then you will only get frustraited. As much as I would like for it to be otherwise blasting is more complicated than it seems.
zymurgist |
Aug 24 2009, 10:27 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I have tried lots of low end blasting and nothing seems to actually work well. The big problem (other than the ones already mentioned) is moisture. If you live in a humid environment and you do not have an air drier and a good compressed then you will only get frustraited. As much as I would like for it to be otherwise blasting is more complicated than it seems. True... I use a short whip hose connected to a last chance water trap (with another water trap attached to my pressure tank where the main hose comes out), and I still can only sandblast for a while in this humid east coast weather. I don't own a sandblaster; I borrowed a siphon blaster. Never used the pressure blaster but all sources indicate that it is a much better tool than a siphon blaster. |
Lo-Fi Version | Time is now: 16th June 2024 - 09:06 AM |
