| blazerchad |
Aug 25 2009, 10:15 AM
Newbie ![]() Group: Members Posts: 35 Joined: 16-August 09 From: portland oregon Member No.: 10,684 Region Association: None |
so my litle silver 1972 1.7 L has been running, not running, running...
i broke a piece in my stock dist. the ball bearing/advance hold down armature. went to a shop, figuring they had parts, they replaced my dist. was not the right dist, shorter dist cap, diff rotor.. so i yarded it out, stole the advance hold down and points, swapped them over and realized I didnt mark my position. then i noticed the dist had an offset connection, only one way to go in! OK, put the new one in, rotate the dist cam, popped into place. reset the points, did a visual dist position and cranked over, no start. odd. checked plug 1,4,3,2 firing order, position of number one on dist and to plug... hmmm... this dist worked fine until it broke, now its fixed... cant buy a new/used one... ive checked around... no love... sigh... |
| blazerchad |
Aug 25 2009, 12:14 PM
that distributor that was put in by the shop was a type 3...
im going backwards to the original... (IMG:http://photos-f.ak.fbcdn.net/hphotos-ak-snc1/hs195.snc1/6576_135583278520_683318520_2344725_3611263_n.jpg) think i found the problem... in the image i have one of the fi contacts broken... fixing that now.. |
blazerchad distributor woes Aug 25 2009, 10:15 AM
SLITS PM sent .... read it. Aug 25 2009, 10:32 AM
underthetire Even if the advance plate is not working at all, t... Aug 25 2009, 10:39 AM
SLITS The shorter cap one is probably the Type 3 distrib... Aug 25 2009, 11:53 AM
rjames
that distributor that was put in by the shop was ... Aug 25 2009, 02:30 PM
blazerchad http://photos-f.ak.fbcdn.net/hphotos-ak-snc1/hs195... Aug 26 2009, 03:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 11:32 AM |
