| jmill |
Sep 15 2008, 09:28 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
This is my new pride and joy. Well, it's not very new but I had to have it once I saw it. I first saw it on Craigs List down in Az. It was sold before I could even reach for the phone. I figured it was long gone. As luck would have it Budman decided to flip it and this baby now sits in my garage. It needs some serious love, but what 914 doesn't.
| jmill |
Aug 26 2009, 11:30 AM
How does the drivers door fit? If that fits and works properly, take measurements and use it to gauge what is going on with the passenger side. How does the targa top fit? Is it pushed back on the passenger side? Drivers door is perfect and closes smooth as butter. Targa top is cockeyed a bit because the window pillar is jazzed. Passenger door closes and gaps are fine but you can tell that the striker has to lift the door up a pinch to fit right. I want it to close as smooth as the drivers side. I'll post pics tonight. The cowl looks fine too. IIRC the front fender to door gap isn't bad either. The only hint that it isn't right is the targa top fit and when you close the door it needs a little extra on it to latch. Do you have anymore pictures of that tool? That looks like just what I need. I can fab up something to work similar if I can see what it looks like. |
| rick 918-S |
Aug 26 2009, 05:13 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,122 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
How does the drivers door fit? If that fits and works properly, take measurements and use it to gauge what is going on with the passenger side. How does the targa top fit? Is it pushed back on the passenger side? Drivers door is perfect and closes smooth as butter. Targa top is cockeyed a bit because the window pillar is jazzed. Passenger door closes and gaps are fine but you can tell that the striker has to lift the door up a pinch to fit right. I want it to close as smooth as the drivers side. I'll post pics tonight. The cowl looks fine too. IIRC the front fender to door gap isn't bad either. The only hint that it isn't right is the targa top fit and when you close the door it needs a little extra on it to latch. Do you have anymore pictures of that tool? That looks like just what I need. I can fab up something to work similar if I can see what it looks like. Yep, just what I thought. I'll get a photo of my spreader. Yes, you can make one with all thread and a piece of tubing. Mine has right and left hand threads so both ends retract or expand But you can get by with one end moving. Don't move the windsheild post. The cowl is tipped back slightly. Push the cowl back with a spreader. Put the tool at the base of the door latch pillar and extend it to the top of the cowl in line with the dash. This will in turn lift the back of the door and move the top of the windsheild pillar out slightly. Again, move a little, check it, move a little, check it. Just for grins, remove the weather seal on the body of both right and left sides. Take a measurement from the base of the pinch weld flange at the latch post to the pinch weld flange next to the upper dash on both the right and left sides. I bet there's 3mm difference. This will continue on up to the top of the windsheild frame. (three thicknesses of a dime) The could show 5mm (five thicknesses of a dime) difference if you go from the lower latch pillar to the top of the winsheild frame. |
jmill Green Hornet Progress Thread Sep 15 2008, 09:28 PM
jmill I'm pealing apart that bent passenger front co... Sep 15 2008, 09:38 PM
jmill As you can see from the picture above the front A ... Sep 15 2008, 09:42 PM
jmill Now it looks much better with most of the bent stu... Sep 15 2008, 09:45 PM
jmill At first I figured I'd be cutting and pasting ... Sep 15 2008, 10:00 PM
jmill Here's a little better picture of the damaged ... Sep 15 2008, 10:08 PM
jmill Once I get it up on the stands I can get a lot dee... Sep 15 2008, 10:18 PM
jmill Any of you 914 body repair experts feel free to pi... Sep 15 2008, 10:27 PM
jmill I was hoping an expert would step up. I'm sti... Sep 18 2008, 09:25 PM
jmill What the heck, another picture. Sep 18 2008, 09:28 PM
74914LE My advice, for the $.02 it is worth, would be... Sep 18 2008, 11:10 PM
jmill Finally got some time to work on it today. I fini... Sep 25 2008, 05:35 PM
jmill Here's the jig bolted up to the green car. As... Sep 25 2008, 05:39 PM
Root_Werks I like the jig! Looks like you have plenty of... Sep 25 2008, 05:39 PM
jmill I wish that the passenger side was the only proble... Sep 25 2008, 05:44 PM
FourBlades I have a spare driver's side front suspension ... Sep 25 2008, 06:12 PM
jmill Thanks for the offer John. My mounts are actually... Sep 25 2008, 08:13 PM
Richard Casto Looks like you are doing a good job. Nice welds o... Sep 26 2008, 08:02 AM
rick 918-S You should have done your pulls before removing th... Sep 26 2008, 09:32 AM
jmill Thanks for the tips Rick. I was hoping an experie... Sep 26 2008, 11:06 AM
jmill Your my hero Rick. I took your advice and rigged ... Sep 28 2008, 06:04 PM
jmill Here's a before picture. Sep 28 2008, 06:08 PM
jmill Here's an after. Sep 28 2008, 06:09 PM
rick 918-S Nice work. Leave the pressure on it and use a bloc... Sep 29 2008, 12:02 AM
jmill With some good advice and a BFH :smash: I finally... Oct 1 2008, 10:42 PM
jmill The front trunk floor needed some work too. I got... Oct 1 2008, 10:55 PM
jmill Here's the after pic. Oct 1 2008, 10:55 PM
rick 918-S Nice work. I'm sure you noticed you needed to ... Oct 2 2008, 08:16 AM
jmill For the last week I haven't seen much progress... Oct 10 2008, 09:58 PM
jmill My wife then reminded me that the garage floor is ... Oct 10 2008, 10:01 PM
jmill Thankfully it all worked out. My sloped floor alm... Oct 10 2008, 10:05 PM
jsayre914 very nice job :bump: Oct 10 2008, 10:45 PM
jmill Thanks Joseph. I got a little more done today. I... Oct 11 2008, 08:14 PM
jmill You can see it alot better in this picture. The f... Oct 11 2008, 08:19 PM
jmill A couple more pics of what I got done today. Oct 12 2008, 05:15 PM
jmill The winter was way too long. I got back to work o... Jul 6 2009, 10:28 PM
jmill After I got the passenger side squared away I need... Jul 6 2009, 10:34 PM
jmill I also started removing the fender. I was bummed ... Jul 6 2009, 10:37 PM
jmill Check out the nasty hood lines around the drivers ... Jul 6 2009, 10:42 PM
jmill Budman these are the parts I'm looking for. Aug 25 2009, 09:41 PM
rick 918-S Maybe one of the west coast guys has a complete go... Aug 26 2009, 07:36 AM
rick 918-S OK, I ran out really fast and did this quick. I th... Aug 26 2009, 08:05 AM
jmill Thanks for the input Rick. Budman (Chris) is out ... Aug 26 2009, 09:16 AM
rick 918-S Oh, I get it. I was thinking you were just working... Aug 26 2009, 10:01 AM
rick 918-S I thought I had a better photo of this tool but yo... Aug 26 2009, 10:24 AM
type11969 Jmill -
Any interest in loaning or selling that ... Aug 26 2009, 02:33 PM
jmill I took a bunch of pics and really looked at the do... Aug 26 2009, 05:28 PM
jmill More pics. Aug 26 2009, 05:37 PM
rick 918-S Yes your vent window will press against the windsh... Aug 26 2009, 05:38 PM
jmill
Any interest in loaning or selling that front su... Aug 26 2009, 05:47 PM
type11969
Any interest in loaning or selling that front s... Aug 26 2009, 05:50 PM
jmill
Do this. Go out to the garage. Remove the targa ... Aug 26 2009, 06:34 PM
rick 918-S
Do this. Go out to the garage. Remove the targa... Aug 26 2009, 07:28 PM
jmill Yup, same measurement. Aug 26 2009, 07:59 PM
rick 918-S
Ok that confirms the co... Aug 26 2009, 09:32 PM
r_towle Im late to the show.
Did you hit something?
If no... Aug 26 2009, 08:52 PM
jmill I didn't hit anything. An owner before me ric... Aug 26 2009, 08:58 PM
r_towle Remove the window.
Set the door perfect.
Then put ... Aug 26 2009, 09:04 PM
rick 918-S No don't remove the window. The window fit the... Aug 26 2009, 09:21 PM
jmill This one isn't sagging. The longs are perfect... Aug 26 2009, 09:49 PM
rick 918-S Here you go. It's hard to see but the jaws hav... Aug 26 2009, 11:58 PM
jmill Thanks for the pictures. No need to ship it. I... Aug 27 2009, 08:02 AM
jmill I haven't done a damn thing in months. Winter... Dec 20 2009, 09:35 PM
rick 918-S John! your next post will be your 914th post... Apr 8 2010, 07:14 AM
rick 918-S :shades2: :bump: Apr 8 2010, 01:53 PM
jmill There was an Alien sighting in Racine Wisconsin th... Apr 18 2010, 07:48 PM
rick 918-S
There was an Alien sighting in Racine Wisconsin t... Apr 19 2010, 07:07 PM
jmill Here's another of picture of "measure 6 t... Apr 18 2010, 07:50 PM
jmill When Rick was through the door closed like butter.... Apr 18 2010, 07:57 PM
jmill Hopefully that engine didn't puke all over the... Apr 18 2010, 08:08 PM
rick 918-S Hi John! 928th :headbanger: Hey, I had a gre... Apr 18 2010, 08:52 PM
jmill Look what showed up today. Thanks Jason. It was ... Jun 3 2010, 08:25 PM
jasons
Look what showed up today. Thanks Jason. It was... Jun 3 2010, 10:19 PM
jmill sf Jun 3 2010, 08:27 PM
effutuo101 Nice! keep up the good work! I am looking ... Jun 3 2010, 10:02 PM
rick 918-S That's going to work out really good! :hea... Jun 3 2010, 10:46 PM
carr914 Bruce Lee, Guy Williams & I approve :thumbsu... Jun 4 2010, 06:51 AM
jmill
Good. I was wondering if you got it yet. Do you... Jun 4 2010, 07:39 AM
rick 918-S
Good. I was wondering if you got it yet. Do yo... Jun 6 2010, 08:47 AM
jmill Haven't touched the fender. Just have time fo... Jun 7 2010, 07:56 PM
jmill The fender is finally going on. I had to take 4 d... Jul 17 2010, 08:42 PM
jmill one more. Jul 17 2010, 08:44 PM
rick 918-S I could end up working over in Milwaukee later in ... Jul 17 2010, 09:09 PM
jmill Completed butt weld and then blended smooth. Jul 18 2010, 05:10 PM
jmill All that work just to chop it out of there and add... Jul 18 2010, 05:12 PM
jmill From the backside. You can see the waves in the A... Jul 18 2010, 05:16 PM
rick 918-S That butt welded seam came out so nice I bet you h... Jul 18 2010, 06:42 PM
jmill
That butt welded seam came out so nice I bet you ... Jul 18 2010, 07:00 PM
budman5201 Looking Great man, keep up the good work! Jul 18 2010, 07:40 PM
Drums66 ..You're doing a great job!(man,I sure mis... Jul 19 2010, 12:34 PM
jmill Drivers side flare going on. Jul 25 2010, 02:29 PM
jmill Going to need some more sanding disks and that bod... Jul 25 2010, 02:32 PM
jmill
... Jul 25 2010, 02:40 PM
faux916
... Jul 25 2010, 03:15 PM
jmill Anybody use one of these and will it work on the w... Jul 25 2010, 02:56 PM
strawman
Anybody use one of these and will it work on the ... Jul 25 2010, 10:56 PM
jmill
Very nice work...The rockers are different sizes ... Jul 25 2010, 07:16 PM
rick 918-S I've never used a shrinking disc. I've alw... Jul 25 2010, 07:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 21st November 2025 - 03:48 PM |
