| jim_hoyland |
Aug 26 2009, 05:48 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,130 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Is the test for bump steer driving over a speed bump straight on or at an angle. I don't get any noticable pulling when taking the speed bump straight on. Just want to get the test situation straight, any input will be appreciated.
Car is lowered about 50% |
| r_towle |
Aug 26 2009, 09:38 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
your fine.
I will never suggest to anyone to put in the bump steer washer.... I put it in and then took it out. It binds things in other places...namely the upper u-joints. You are not low enough to have bump steer. You are damn close... If you are not autoxing the car I would suggest you raise the whole car 1/4 of an inch measured from the fender lips. It will ride better. Rich |
| jim_hoyland |
Aug 26 2009, 09:40 PM
your fine. I will never suggest to anyone to put in the bump steer washer.... I put it in and then took it out. It binds things in other places...namely the upper u-joints. You are not low enough to have bump steer. You are damn close... If you are not autoxing the car I would suggest you raise the whole car 1/4 of an inch measured from the fender lips. It will ride better. Rich Thanks; 1/4 should be doable. Just a DD, no AX |
jim_hoyland Bump Steer Aug 26 2009, 05:48 PM
ConeDodger Jim,
I have never heard of a test for bump steer b... Aug 26 2009, 07:20 PM
underthetire If you get a "that feels kinda funny" ma... Aug 26 2009, 09:05 PM
r_towle Jim,
Take a pic of your car, on the ground.
Lay do... Aug 26 2009, 09:10 PM
jim_hoyland
Jim,
Lay d... Aug 26 2009, 09:13 PM
orange914
Post that so we can see the whole a-arm.
RIch
l... Aug 26 2009, 09:20 PM
orange914
Is the test for bump steer driving over a speed b... Aug 26 2009, 09:14 PM
jim_hoyland Pics: Aug 26 2009, 09:27 PM
ArtechnikA
It binds things in other places...namely the uppe... Aug 27 2009, 07:54 PM
jaxdream
It binds things in other places...namely the upp... Aug 27 2009, 08:37 PM
stewteral
Is the test for bump steer driving over a speed b... Aug 26 2009, 09:55 PM
J P Stein
I hope all my work can help you understand what... Aug 27 2009, 03:17 PM
turboman808 Wouldn't you idealy like the tie rod to be par... Aug 26 2009, 10:13 PM
orange914 i really don't have real world experiance with... Aug 26 2009, 10:17 PM
orange914 looking at the picture and reading rich's comm... Aug 26 2009, 10:35 PM
r_towle
looking at the picture and reading rich's com... Aug 26 2009, 10:39 PM
Tie rods always need to be at an angle
:confused... Aug 26 2009, 10:47 PM
orange914
:confuse... Aug 26 2009, 11:14 PM
jmill There is a bump steer test. It's alot easier ... Aug 27 2009, 08:16 AM
jim_hoyland Thanks Terry-That is a good explanation. Am I corr... Aug 27 2009, 08:25 AM
Cevan From my own experience, my car had pretty signific... Aug 27 2009, 10:17 AM
gopack Elephant racing makes the tie rod end solution. L... Aug 27 2009, 12:57 PM
... Aug 27 2009, 01:01 PM
turboman808 I really thought my car had this and just needed s... Aug 27 2009, 01:28 PM
jim_hoyland Does raising the spindles or using the ER bump ste... Aug 27 2009, 02:59 PM
Does raising the spindles or using the ER bump st... Aug 27 2009, 03:02 PM
turboman808
Does raising the spindles or using the ER bump st... Aug 27 2009, 03:13 PM
J P Stein Angles..we gots em and it works. I'm at 4-3/4 ... Aug 27 2009, 06:33 PM
Yeah, but your ... Aug 27 2009, 06:40 PM
J P Stein I have 2 1/2 inches of front shock travel & us... Aug 27 2009, 06:55 PM
cwpeden You need to account for the pivot points of the ti... Aug 27 2009, 07:10 PM
J P Stein
You need to account for the pivot points of the t... Aug 27 2009, 07:20 PM
dw914er This is what is on clubrsx from my searches while ... Aug 27 2009, 08:58 PM
jim_hoyland
This is what is on clubrsx from my searches while... Aug 27 2009, 09:48 PM
dw914er Then that's probably why...
when you drop a c... Aug 28 2009, 12:33 AM
SLITS HP Books - "How to Make Your Car Handle... Aug 28 2009, 08:17 AM
jmill I like "Tune to Win" and "Engineer ... Aug 28 2009, 09:58 AM
turboman808 Wrote this long thing and then just made a diagram... Aug 28 2009, 10:46 AM
jim_hoyland
Wrote this long thing and then just made a diagra... Aug 28 2009, 11:23 AM
turboman808 Well keep in mind I haven't got a clue what I ... Aug 28 2009, 12:18 PM
Borderline
Well keep in mind I haven't got a clue what I... Aug 28 2009, 02:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th September 2026 - 06:55 AM |
