| KaptKaos |
Aug 27 2009, 11:51 AM
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I got a set of tires from a friend. They're not bad and I'd like to use them BUT at some point someone (my friend) spilled paint on the tires. I am sure I will wear off the paint on the threads, but there is some on the sidewall.
Is there a safe way to take that off without compromising the rubber in the tire? It's home paint, not automotive grade. TIA |
tracks914 Sandblast, fast and won't hurt the rubber. Aug 27 2009, 11:54 AM
turnaround89 ive heard a small amount of gasoline will remove i... Aug 27 2009, 12:01 PM
zymurgist Can you mount the tire with the painted sidewall f... Aug 27 2009, 12:01 PM
tradisrad try a brush. Aug 27 2009, 12:58 PM
r_towle steel wool. Aug 28 2009, 11:06 PM
iamchappy brake fluid...... scotch brite pad Aug 28 2009, 11:45 PM
gothspeed Scotch brite and water. Aug 29 2009, 12:06 PM
kwales Curbs, I use curbs.....
Works every time..
Ditto... Aug 29 2009, 12:38 PM
Nana's_914 You could try MEK(METHYL ETHYL KETONE) and a rag i... Aug 29 2009, 05:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th June 2026 - 12:34 PM |
