> Bump Steer, How to tell...?
jim_hoyland
post Aug 26 2009, 05:48 PM
Get that VIN ?
Is the test for bump steer driving over a speed bump straight on or at an angle. I don't get any noticable pulling when taking the speed bump straight on. Just want to get the test situation straight, any input will be appreciated.
Car is lowered about 50%
dw914er
post Aug 27 2009, 08:58 PM
Planning Cities
This is what is on clubrsx from my searches while modifying my suspension on my rsx
First, I'll talk about what bumpsteer is NOT. It is NOT when the steering wheel moves when you hit a bump. That often is caused by high spring rates or high tie pressures. Imagine riding your bike with no tires. As soon as it hits a bump, you are going to feel it and it is going to push your wheel in a certain direction. When spring rates or tire pressures are really high, the suspension is really stiff and the car responds quickly and not necessarily in the right way. Remember, high spring rates don't = better handling. Race cars use high spring rates because they allow quick responding, but they also are racing on smooth surfaces and not on crappy city roads.
The short answer is that bumpsteer is when your wheels turn without input from the driver. It is affected by toe. On our suspension, when it compresses, toe goes in and the opposite happens with rebound. To control bumpsteer, one would want to keep toe settings pretty static throughout compression and rebound.
From what I understand, camber can and will affect toe, so the common results of bumpsteer from after lowering a car is bad alignment, creating what the quote said. Is this true, and could be why Jim hasn't noticed massive bumpsteer, because the alignment probably isn't that far out of wack? I don't really know, but alot of their stickies makes sense for the rsx applications, so I assumed this one was good also.
jim_hoyland
post Aug 27 2009, 09:48 PM
Get that VIN ?
QUOTE(dw914er @ Aug 27 2009, 07:58 PM) *
The alignment is pretty close; forgot the numbers. Tire wear is even as well
jim_hoyland   Bump Steer   Aug 26 2009, 05:48 PM
ConeDodger   Jim, I have never heard of a test for bump steer b...   Aug 26 2009, 07:20 PM
underthetire   If you get a "that feels kinda funny" ma...   Aug 26 2009, 09:05 PM
r_towle   Jim, Take a pic of your car, on the ground. Lay do...   Aug 26 2009, 09:10 PM
jim_hoyland   Jim, Take a pic of your car, on the ground. Lay d...   Aug 26 2009, 09:13 PM
orange914   Post that so we can see the whole a-arm. RIch l...   Aug 26 2009, 09:20 PM
orange914   Is the test for bump steer driving over a speed b...   Aug 26 2009, 09:14 PM
jim_hoyland   Pics:   Aug 26 2009, 09:27 PM
r_towle   your fine. I will never suggest to anyone to put ...   Aug 26 2009, 09:38 PM
jim_hoyland   your fine. I will never suggest to anyone to put...   Aug 26 2009, 09:40 PM
ArtechnikA   It binds things in other places...namely the uppe...   Aug 27 2009, 07:54 PM
jaxdream   It binds things in other places...namely the upp...   Aug 27 2009, 08:37 PM
stewteral   Is the test for bump steer driving over a speed b...   Aug 26 2009, 09:55 PM
J P Stein   I hope all my work can help you understand what...   Aug 27 2009, 03:17 PM
turboman808   Wouldn't you idealy like the tie rod to be par...   Aug 26 2009, 10:13 PM
orange914   i really don't have real world experiance with...   Aug 26 2009, 10:17 PM
orange914   looking at the picture and reading rich's comm...   Aug 26 2009, 10:35 PM
r_towle   looking at the picture and reading rich's com...   Aug 26 2009, 10:39 PM
SirAndy   Tie rods always need to be at an angle :confused...   Aug 26 2009, 10:47 PM
orange914   Tie rods always need to be at an angle :confuse...   Aug 26 2009, 11:14 PM
jmill   There is a bump steer test. It's alot easier ...   Aug 27 2009, 08:16 AM
jim_hoyland   Thanks Terry-That is a good explanation. Am I corr...   Aug 27 2009, 08:25 AM
Cevan   From my own experience, my car had pretty signific...   Aug 27 2009, 10:17 AM
gopack   Elephant racing makes the tie rod end solution. L...   Aug 27 2009, 12:57 PM
SirAndy   Elephant racing makes the tie rod end solution. ...   Aug 27 2009, 01:01 PM
turboman808   I really thought my car had this and just needed s...   Aug 27 2009, 01:28 PM
jim_hoyland   Does raising the spindles or using the ER bump ste...   Aug 27 2009, 02:59 PM
SirAndy   Does raising the spindles or using the ER bump st...   Aug 27 2009, 03:02 PM
turboman808   Does raising the spindles or using the ER bump st...   Aug 27 2009, 03:13 PM
J P Stein   Angles..we gots em and it works. I'm at 4-3/4 ...   Aug 27 2009, 06:33 PM
SirAndy   Angles..we gots em and it works. Yeah, but your ...   Aug 27 2009, 06:40 PM
J P Stein   I have 2 1/2 inches of front shock travel & us...   Aug 27 2009, 06:55 PM
cwpeden   You need to account for the pivot points of the ti...   Aug 27 2009, 07:10 PM
J P Stein   You need to account for the pivot points of the t...   Aug 27 2009, 07:20 PM
dw914er   This is what is on clubrsx from my searches while ...   Aug 27 2009, 08:58 PM
jim_hoyland   This is what is on clubrsx from my searches while...   Aug 27 2009, 09:48 PM
dw914er   Then that's probably why... when you drop a c...   Aug 28 2009, 12:33 AM
SLITS   HP Books - "How to Make Your Car Handle...   Aug 28 2009, 08:17 AM
jmill   I like "Tune to Win" and "Engineer ...   Aug 28 2009, 09:58 AM
turboman808   Wrote this long thing and then just made a diagram...   Aug 28 2009, 10:46 AM
jim_hoyland   Wrote this long thing and then just made a diagra...   Aug 28 2009, 11:23 AM
turboman808   Well keep in mind I haven't got a clue what I ...   Aug 28 2009, 12:18 PM
Borderline   Well keep in mind I haven't got a clue what I...   Aug 28 2009, 02:52 PM
- Lo-Fi Version Time is now: 13th September 2026 - 06:55 AM
