Rear Fender, Remove and replace |
watsonrx13 |
Feb 11 2004, 06:17 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I've got the burnt 914 that needs the left rear fender removed and replaced. I have a parts car that has a good fender. I also want to replace the sail panel. How should I remove the fender? However you recommend, I'll use the exact same method for removing the parts car item. Once I remove the fender, I'll need to replace the door striker and some inner engine compartment sheet metal. Please be very specific and provide pics if possible. Thanks again for all of your help.
Attached image(s) |
kafermeister |
Feb 11 2004, 09:16 PM
Senior Member Group: Members Posts: 778 Joined: 20-January 03 From: Cincinnati/Northern KY Member No.: 174 |
QUOTE(watsonrx13 @ Feb 11 2004, 11:04 PM) Is the fender and the targa panel a single piece? Yes. The outer targa panel, fender are one piece. In fact, the door jam should be kept with the quarter to make things simpler. The hard part is the fresh air pickup (vent?) in the door jam. Send me a PM to remind me and I will take some pics of rear quarters tomorow that have been removed via the spot welds so you can see what's involved. Rick |
Lo-Fi Version | Time is now: 29th May 2024 - 04:08 AM |
