| SirAndy |
Aug 18 2009, 12:45 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,473 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My '95 993 Motor is a pre-varioram OBD1 Motor and i have been toying with the idea of updating it to OBD2.
There was, for a short time, a OBD2 brain available for the (still aircooled) 993 starting in '96 with the varioram version of the motor. It is my understanding that besides the tubes inside the intake, the two motors are pretty much identical. I wonder if i could get a later brain and harness and make it work with my engine. Is there anyone out there who has tried this? (IMG:style_emoticons/default/idea.gif) Andy |
| SirAndy |
Sep 3 2009, 02:14 PM
Looks like i found a solution! (IMG:style_emoticons/default/cheer.gif)
They have a version for older cars that let's you bypass the whole OBD2 stuff and just run GPS, Speed, Heading and G-Force. It uses a Driveshaft/CV sensor to get good Speed sampling and the satellite link works just as in the more modern cars. I'll be installing the kit tomorrow. We'll see how that goes ... (IMG:style_emoticons/default/piratenanner.gif) Andy |
| RJMII |
Sep 3 2009, 02:51 PM
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
Looks like i found a solution! (IMG:style_emoticons/default/cheer.gif) They have a version for older cars that let's you bypass the whole OBD2 stuff and just run GPS, Speed, Heading and G-Force. It uses a Driveshaft/CV sensor to get good Speed sampling and the satellite link works just as in the more modern cars. I'll be installing the kit tomorrow. We'll see how that goes ... (IMG:style_emoticons/default/piratenanner.gif) Andy ah, so that's what the picture I took was for! awesome. =o) |
SirAndy Changing '95 993 Motor to OBD2 brain? Doable? Aug 18 2009, 12:45 AM
SirAndy Maybe i need to post this on 993world.com ... :D Aug 18 2009, 03:36 PM
r_towle I dont see why not.
You would need to verify the v... Aug 18 2009, 03:40 PM
Cupomeat The basic hard parts of the 95 and 96-98 993 3.6l ... Aug 18 2009, 03:56 PM
Why do the coversion?
I have access to an OBD2 w... Aug 18 2009, 07:14 PM
ghuff Why go OBDII, why not go stand alone?
What is be... Aug 18 2009, 04:13 PM
McMark Cool! :thumbsup: Aug 18 2009, 07:22 PM
Chris Hamilton I'd go with an aftermarket ECU that does OBD I... Aug 18 2009, 07:24 PM
Cap'n Krusty From what OBD2 stuff I deal with, I have a couple ... Aug 18 2009, 07:39 PM
From what OBD2 stuff I deal with, I have a couple... Aug 18 2009, 08:53 PM
ghuff
From what OBD2 stuff I deal with, I have a couple... Aug 18 2009, 08:56 PM
What you are looking for, you need standalone. Fo... Aug 18 2009, 09:00 PM
ghuff
[quote name='ghuff' post='1204358' date='Aug 18 2... Aug 18 2009, 09:16 PM
Perhaps I can clarify it more for you if need be?... Aug 19 2009, 01:19 AM
ghuff
Perhaps I can clarify it more for you if need be... Aug 20 2009, 12:49 AM
r_towle Andy,
the system will be monitoring fuel, emmissi... Aug 18 2009, 11:03 PM
Andy,
the system will be monitoring fuel, emmiss... Aug 19 2009, 01:23 AM
ClayPerrine Andy....
You do realize that a varioram intake wo... Aug 19 2009, 07:24 AM
SirAndy Maybe it would be easier to figure out how to conv... Aug 19 2009, 11:31 AM
Chris Hamilton
Maybe it would be easier to figure out how to con... Aug 19 2009, 12:36 PM
r_towle Andy,
How much would and ECU/brain/harness etc co... Aug 20 2009, 09:03 AM
How much would and ECU/brain/harness etc cost fro... Aug 20 2009, 11:26 AM
RJMII Wait... it by-passes the OBD2? So I could use it w... Sep 3 2009, 03:00 PM
which unit do you have?
Well, that's the cat... Sep 3 2009, 03:46 PM
McMark If you wanna install here, you're welcome... Sep 3 2009, 03:13 PM
If you wanna install here, you're welcome... Sep 3 2009, 03:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th April 2026 - 01:02 AM |
