> Horizontal Fans, Again, sorry...
Rod
post Sep 6 2009, 12:39 PM
Region Association: England
So I want to get a fresh block and rebuild a 2270 street engine. I have always loved the look of horizontal fans and would really like to integrate this into the build.
I have seen a few, (even an electric one) but which would be recommended? Would it be worth looking into building a 90 degree coupling? (or would it be too power sapping) - I have access to lots of billet and machinery, so If anyone has done such a thing I would be very interested to see what you have done.
Anybody running a HF in a Fourteener? Would love to see pics if so.
Thanks in advance.
ChrisFoley
post Sep 8 2009, 09:06 AM
I am Tangerine Racing
That Corvair alternator location doesn't work with our engines due to distributor placement.
My plan would be to keep the stock alternator location and run a separate belt.
VaccaRabite
post Sep 8 2009, 09:20 AM
En Garde!
QUOTE(Racer Chris @ Sep 8 2009, 10:06 AM) *
Why not just put it on the non-distributor side?
Its a little fabrication either way, but using one belt is easier then using two.
Zach
Rod   Horizontal Fans   Sep 6 2009, 12:39 PM
Johny Blackstain   and/ or a six? :popcorn:   Sep 6 2009, 12:41 PM
Rod   and/ or a six? :popcorn: This car I'm keep...   Sep 6 2009, 12:45 PM
URY914   RacerChris has one in his race car.   Sep 6 2009, 12:42 PM
r_towle   Chris uses a modifed Corvair horizontal fan. Searc...   Sep 6 2009, 01:11 PM
Rod   Thanks, Reichert - http://www.riechertmotorentech...   Sep 6 2009, 01:17 PM
Dr Evil   Get parts form a corvair and save some $...   Sep 6 2009, 05:45 PM
Aaron Cox   i doubt youll gain anything.... you'll pick u...   Sep 6 2009, 05:47 PM
URY914   i doubt youll gain anything.... you'll pick ...   Sep 6 2009, 07:46 PM
orange914   i doubt youll gain anything.... you'll pick ...   Sep 6 2009, 10:54 PM
iamchappy   Marty's...   Sep 6 2009, 05:56 PM
JazonJJordan   That just made me (((cry))) ........1995 and ...   Sep 6 2009, 06:25 PM
number6   http://forums.pelicanparts.com/showthread....97138...   Sep 6 2009, 06:43 PM
veltror   My mate in Southern germany had one on his 2.4. he...   Sep 7 2009, 09:56 AM
zymurgist   I wonder if the Corvair type belts are special, i....   Sep 7 2009, 10:06 AM
DBCooper   Later Corvairs were modified so there was an adjus...   Sep 7 2009, 11:23 AM
r_towle   Again, talk to Chris Foley...he seems to have figu...   Sep 7 2009, 11:24 AM
zymurgist   Porsche used the horizontal fans on most of the b...   Sep 7 2009, 11:57 AM
Jake Raby   Porsche used the horizontal fans on most of the ...   Sep 7 2009, 04:27 PM
Dr Evil   I have never seen the spring tension type and I ha...   Sep 7 2009, 11:39 AM
Vacca Rabite   Also, make sure that what ever you do leaves you w...   Sep 7 2009, 04:38 PM
r_towle   Also, make sure that what ever you do leaves you ...   Sep 7 2009, 04:57 PM
ClayPerrine   Also, make sure that what ever you do leaves you...   Sep 7 2009, 05:04 PM
Vacca Rabite   [quote name='r_towle' post='1211880' date='Sep 7 ...   Sep 8 2009, 07:20 AM
Rod   [quote name='r_towle' post='1211880' date='Sep 7...   Sep 8 2009, 08:36 AM
turboman808   Yup. This is how it looks (using Mike's engi...   Sep 8 2009, 12:54 PM
Rod   Thanks for all the help and information so far. I...   Sep 7 2009, 05:23 PM
Racer Chris   Thanks for all the help and information so far. ...   Sep 7 2009, 08:59 PM
DBCooper   The 911 fans are not the correct type of fan for h...   Sep 8 2009, 11:08 AM
lotus_65   it does look cool... i think of these :wub: but ...   Sep 7 2009, 07:09 PM
Racer Chris   That Corvair alternator location doesn't work ...   Sep 8 2009, 09:06 AM
Vacca Rabite   That Corvair alternator location doesn't work...   Sep 8 2009, 09:20 AM
ottox914   That Corvair alternator location doesn't work...   Sep 16 2009, 09:19 AM
Dr Evil   I think the sprung tensioner you were referring to...   Sep 8 2009, 12:00 PM
zymurgist   I find it interesting that a 2.7L 6cyl engine onl...   Sep 8 2009, 12:06 PM
Dr Evil   I find it interesting that a 2.7L 6cyl engine on...   Sep 8 2009, 07:34 PM
Dr Evil   More info from one of the vair forums: "Buy ...   Sep 8 2009, 12:04 PM
904svo   I like a vertical setup better, this is my version...   Sep 8 2009, 08:21 PM
Maltese Falcon   Downward airflow, and its equally channeled ductin...   Sep 8 2009, 09:34 PM
mskala   Downward airflow, and its equally channeled ducti...   Sep 9 2009, 11:53 AM
zymurgist   The engine RPM and fan RPM don't match linear...   Sep 9 2009, 12:17 PM
Nana's_914   The engine RPM and fan RPM don't match linea...   Sep 9 2009, 01:32 PM
mskala   The engine RPM and fan RPM don't match linea...   Sep 9 2009, 07:42 PM
Maltese Falcon   This is how the belt tensioner is situated on the ...   Sep 8 2009, 09:43 PM
DBCooper   The opposite should be true. At some point as the...   Sep 9 2009, 01:52 PM
jd74914   I would love to see a more conventional fan curve ...   Sep 9 2009, 02:34 PM
Type 4 Unleashed   :WTF:   Sep 10 2009, 01:47 AM
Jake Raby   They probably do.. I am doing some work with a gil...   Sep 10 2009, 04:16 PM
Rod   They probably do.. I am doing some work with a gi...   Sep 15 2009, 05:06 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:38 PM
