| Rod |
Sep 6 2009, 12:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
So I want to get a fresh block and rebuild a 2270 street engine. I have always loved the look of horizontal fans and would really like to integrate this into the build.
I have seen a few, (even an electric one) but which would be recommended? Would it be worth looking into building a 90 degree coupling? (or would it be too power sapping) - I have access to lots of billet and machinery, so If anyone has done such a thing I would be very interested to see what you have done. Anybody running a HF in a Fourteener? Would love to see pics if so. Thanks in advance. |
| Dr Evil |
Sep 8 2009, 12:04 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
More info from one of the vair forums:
"Buy a Clarks belt and be sure not to over tighten it. A properly adjusted belt should allow you to turn the Alt or Gen fan with 2 fingers; if you can't turn the fan with 2 fingers it's too tight. Also correct alignment and clean rust free pulley surfaces are crucial to belt life." Located here for more info: http://corvaircenter.com/phorum/read.php?1,232721,233005 |
Rod Horizontal Fans Sep 6 2009, 12:39 PM
Johny Blackstain and/ or a six?
:popcorn: Sep 6 2009, 12:41 PM
Rod
and/ or a six?
:popcorn:
This car I'm keep... Sep 6 2009, 12:45 PM
URY914 RacerChris has one in his race car. Sep 6 2009, 12:42 PM
r_towle Chris uses a modifed Corvair horizontal fan.
Searc... Sep 6 2009, 01:11 PM
Rod Thanks, Reichert - http://www.riechertmotorentech... Sep 6 2009, 01:17 PM
Dr Evil Get parts form a corvair and save some $... Sep 6 2009, 05:45 PM
Aaron Cox i doubt youll gain anything....
you'll pick u... Sep 6 2009, 05:47 PM
URY914
you'll pick ... Sep 6 2009, 07:46 PM
orange914
you'll pick ... Sep 6 2009, 10:54 PM
iamchappy Marty's... Sep 6 2009, 05:56 PM
JazonJJordan That just made me (((cry)))
........1995 and ... Sep 6 2009, 06:25 PM
number6 http://forums.pelicanparts.com/showthread....97138... Sep 6 2009, 06:43 PM
veltror My mate in Southern germany had one on his 2.4. he... Sep 7 2009, 09:56 AM
zymurgist I wonder if the Corvair type belts are special, i.... Sep 7 2009, 10:06 AM
DBCooper Later Corvairs were modified so there was an adjus... Sep 7 2009, 11:23 AM
r_towle Again, talk to Chris Foley...he seems to have figu... Sep 7 2009, 11:24 AM
zymurgist
Porsche used the horizontal fans on most of the b... Sep 7 2009, 11:57 AM
Jake Raby
Porsche used the horizontal fans on most of the ... Sep 7 2009, 04:27 PM
Dr Evil I have never seen the spring tension type and I ha... Sep 7 2009, 11:39 AM
Vacca Rabite Also, make sure that what ever you do leaves you w... Sep 7 2009, 04:38 PM
r_towle
Also, make sure that what ever you do leaves you ... Sep 7 2009, 04:57 PM
ClayPerrine
Also, make sure that what ever you do leaves you... Sep 7 2009, 05:04 PM
Vacca Rabite
[quote name='r_towle' post='1211880' date='Sep 7 ... Sep 8 2009, 07:20 AM
Rod
[quote name='r_towle' post='1211880' date='Sep 7... Sep 8 2009, 08:36 AM
turboman808
Yup.
This is how it looks (using Mike's engi... Sep 8 2009, 12:54 PM
Rod Thanks for all the help and information so far. I... Sep 7 2009, 05:23 PM
Racer Chris
Thanks for all the help and information so far. ... Sep 7 2009, 08:59 PM
DBCooper The 911 fans are not the correct type of fan for h... Sep 8 2009, 11:08 AM
lotus_65 it does look cool... i think of these :wub:
but ... Sep 7 2009, 07:09 PM
Racer Chris That Corvair alternator location doesn't work ... Sep 8 2009, 09:06 AM
Vacca Rabite
That Corvair alternator location doesn't work... Sep 8 2009, 09:20 AM
ottox914
That Corvair alternator location doesn't work... Sep 16 2009, 09:19 AM
Dr Evil I think the sprung tensioner you were referring to... Sep 8 2009, 12:00 PM
zymurgist
I find it interesting that a 2.7L 6cyl engine onl... Sep 8 2009, 12:06 PM
Dr Evil
I find it interesting that a 2.7L 6cyl engine on... Sep 8 2009, 07:34 PM
904svo I like a vertical setup better, this is my version... Sep 8 2009, 08:21 PM
Maltese Falcon Downward airflow, and its equally channeled ductin... Sep 8 2009, 09:34 PM
mskala
Downward airflow, and its equally channeled ducti... Sep 9 2009, 11:53 AM
zymurgist
The engine RPM and fan RPM don't match linear... Sep 9 2009, 12:17 PM
Nana's_914
The engine RPM and fan RPM don't match linea... Sep 9 2009, 01:32 PM
mskala
The engine RPM and fan RPM don't match linea... Sep 9 2009, 07:42 PM
Maltese Falcon This is how the belt tensioner is situated on the ... Sep 8 2009, 09:43 PM
DBCooper The opposite should be true. At some point as the... Sep 9 2009, 01:52 PM
jd74914 I would love to see a more conventional fan curve ... Sep 9 2009, 02:34 PM
Type 4 Unleashed :WTF: Sep 10 2009, 01:47 AM
Jake Raby They probably do.. I am doing some work with a gil... Sep 10 2009, 04:16 PM
Rod
They probably do.. I am doing some work with a gi... Sep 15 2009, 05:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:45 PM |
