| Rod |
Sep 6 2009, 12:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
So I want to get a fresh block and rebuild a 2270 street engine. I have always loved the look of horizontal fans and would really like to integrate this into the build.
I have seen a few, (even an electric one) but which would be recommended? Would it be worth looking into building a 90 degree coupling? (or would it be too power sapping) - I have access to lots of billet and machinery, so If anyone has done such a thing I would be very interested to see what you have done. Anybody running a HF in a Fourteener? Would love to see pics if so. Thanks in advance. |
| Dr Evil |
Sep 8 2009, 12:00 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I think the sprung tensioner you were referring to is this one:
http://www.corvair.com/user-cgi/catalog.cg...AIN&page=15 They were never stock and this one is $109. As for the fan, notice that mine has practically vertical fins. This was a change in 65 as the older fans, more like the squirrel cage, supposedly cooled too much. I find it interesting that a 2.7L 6cyl engine only needed a vertically bladed fan to keep it cool. |
| zymurgist |
Sep 8 2009, 12:06 PM
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I find it interesting that a 2.7L 6cyl engine only needed a vertically bladed fan to keep it cool. Didn't the 2.7's have cooling issues? (IMG:style_emoticons/default/wink.gif) Yeah, I know, self-inflicted... Porsche intentionally made the engines run hot (5 blade fan) in order to make the thermal reactor work. |
| Dr Evil |
Sep 8 2009, 07:34 PM
I find it interesting that a 2.7L 6cyl engine only needed a vertically bladed fan to keep it cool. Didn't the 2.7's have cooling issues? (IMG:style_emoticons/default/wink.gif) Yeah, I know, self-inflicted... Porsche intentionally made the engines run hot (5 blade fan) in order to make the thermal reactor work. Let me clarify, all corvair engines were 2.7L from 65-69 no matter the HP. They changed number of carbs, size of valves, but the displacement stayed the same. The fan you see on my engine was what they also switched to. It has fan blades with no discernible pitch to them. Before this the fans had blades like our squirrel cages. |
Rod Horizontal Fans Sep 6 2009, 12:39 PM
Johny Blackstain and/ or a six?
:popcorn: Sep 6 2009, 12:41 PM
Rod
and/ or a six?
:popcorn:
This car I'm keep... Sep 6 2009, 12:45 PM
URY914 RacerChris has one in his race car. Sep 6 2009, 12:42 PM
r_towle Chris uses a modifed Corvair horizontal fan.
Searc... Sep 6 2009, 01:11 PM
Rod Thanks, Reichert - http://www.riechertmotorentech... Sep 6 2009, 01:17 PM
Dr Evil Get parts form a corvair and save some $... Sep 6 2009, 05:45 PM
Aaron Cox i doubt youll gain anything....
you'll pick u... Sep 6 2009, 05:47 PM
URY914
you'll pick ... Sep 6 2009, 07:46 PM
orange914
you'll pick ... Sep 6 2009, 10:54 PM
iamchappy Marty's... Sep 6 2009, 05:56 PM
JazonJJordan That just made me (((cry)))
........1995 and ... Sep 6 2009, 06:25 PM
number6 http://forums.pelicanparts.com/showthread....97138... Sep 6 2009, 06:43 PM
veltror My mate in Southern germany had one on his 2.4. he... Sep 7 2009, 09:56 AM
zymurgist I wonder if the Corvair type belts are special, i.... Sep 7 2009, 10:06 AM
DBCooper Later Corvairs were modified so there was an adjus... Sep 7 2009, 11:23 AM
r_towle Again, talk to Chris Foley...he seems to have figu... Sep 7 2009, 11:24 AM
zymurgist
Porsche used the horizontal fans on most of the b... Sep 7 2009, 11:57 AM
Jake Raby
Porsche used the horizontal fans on most of the ... Sep 7 2009, 04:27 PM
Dr Evil I have never seen the spring tension type and I ha... Sep 7 2009, 11:39 AM
Vacca Rabite Also, make sure that what ever you do leaves you w... Sep 7 2009, 04:38 PM
r_towle
Also, make sure that what ever you do leaves you ... Sep 7 2009, 04:57 PM
ClayPerrine
Also, make sure that what ever you do leaves you... Sep 7 2009, 05:04 PM
Vacca Rabite
[quote name='r_towle' post='1211880' date='Sep 7 ... Sep 8 2009, 07:20 AM
Rod
[quote name='r_towle' post='1211880' date='Sep 7... Sep 8 2009, 08:36 AM
turboman808
Yup.
This is how it looks (using Mike's engi... Sep 8 2009, 12:54 PM
Rod Thanks for all the help and information so far. I... Sep 7 2009, 05:23 PM
Racer Chris
Thanks for all the help and information so far. ... Sep 7 2009, 08:59 PM
DBCooper The 911 fans are not the correct type of fan for h... Sep 8 2009, 11:08 AM
lotus_65 it does look cool... i think of these :wub:
but ... Sep 7 2009, 07:09 PM
Racer Chris That Corvair alternator location doesn't work ... Sep 8 2009, 09:06 AM
Vacca Rabite
That Corvair alternator location doesn't work... Sep 8 2009, 09:20 AM
ottox914
That Corvair alternator location doesn't work... Sep 16 2009, 09:19 AM
Dr Evil More info from one of the vair forums:
"Buy ... Sep 8 2009, 12:04 PM
904svo I like a vertical setup better, this is my version... Sep 8 2009, 08:21 PM
Maltese Falcon Downward airflow, and its equally channeled ductin... Sep 8 2009, 09:34 PM
mskala
Downward airflow, and its equally channeled ducti... Sep 9 2009, 11:53 AM
zymurgist
The engine RPM and fan RPM don't match linear... Sep 9 2009, 12:17 PM
Nana's_914
The engine RPM and fan RPM don't match linea... Sep 9 2009, 01:32 PM
mskala
The engine RPM and fan RPM don't match linea... Sep 9 2009, 07:42 PM
Maltese Falcon This is how the belt tensioner is situated on the ... Sep 8 2009, 09:43 PM
DBCooper The opposite should be true. At some point as the... Sep 9 2009, 01:52 PM
jd74914 I would love to see a more conventional fan curve ... Sep 9 2009, 02:34 PM
Type 4 Unleashed :WTF: Sep 10 2009, 01:47 AM
Jake Raby They probably do.. I am doing some work with a gil... Sep 10 2009, 04:16 PM
Rod
They probably do.. I am doing some work with a gi... Sep 15 2009, 05:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:16 PM |
