> Horizontal Fans, Again, sorry...
Rod
post Sep 6 2009, 12:39 PM
Region Association: England
So I want to get a fresh block and rebuild a 2270 street engine. I have always loved the look of horizontal fans and would really like to integrate this into the build.
I have seen a few, (even an electric one) but which would be recommended? Would it be worth looking into building a 90 degree coupling? (or would it be too power sapping) - I have access to lots of billet and machinery, so If anyone has done such a thing I would be very interested to see what you have done.
Anybody running a HF in a Fourteener? Would love to see pics if so.
Thanks in advance.
DBCooper
post Sep 9 2009, 01:52 PM
14's in the 13's with ATTITUDE
The opposite should be true. At some point as the RPM and blade velocity increases the blades won't be able to replenish at the same rate, so the curve will flatten. But RPM's in the graph should increase in a straight line.
Rod   Horizontal Fans   Sep 6 2009, 12:39 PM
Johny Blackstain   and/ or a six? :popcorn:   Sep 6 2009, 12:41 PM
Rod   and/ or a six? :popcorn: This car I'm keep...   Sep 6 2009, 12:45 PM
URY914   RacerChris has one in his race car.   Sep 6 2009, 12:42 PM
r_towle   Chris uses a modifed Corvair horizontal fan. Searc...   Sep 6 2009, 01:11 PM
Rod   Thanks, Reichert - http://www.riechertmotorentech...   Sep 6 2009, 01:17 PM
Dr Evil   Get parts form a corvair and save some $...   Sep 6 2009, 05:45 PM
Aaron Cox   i doubt youll gain anything.... you'll pick u...   Sep 6 2009, 05:47 PM
URY914   i doubt youll gain anything.... you'll pick ...   Sep 6 2009, 07:46 PM
orange914   i doubt youll gain anything.... you'll pick ...   Sep 6 2009, 10:54 PM
iamchappy   Marty's...   Sep 6 2009, 05:56 PM
JazonJJordan   That just made me (((cry))) ........1995 and ...   Sep 6 2009, 06:25 PM
number6   http://forums.pelicanparts.com/showthread....97138...   Sep 6 2009, 06:43 PM
veltror   My mate in Southern germany had one on his 2.4. he...   Sep 7 2009, 09:56 AM
zymurgist   I wonder if the Corvair type belts are special, i....   Sep 7 2009, 10:06 AM
DBCooper   Later Corvairs were modified so there was an adjus...   Sep 7 2009, 11:23 AM
r_towle   Again, talk to Chris Foley...he seems to have figu...   Sep 7 2009, 11:24 AM
zymurgist   Porsche used the horizontal fans on most of the b...   Sep 7 2009, 11:57 AM
Jake Raby   Porsche used the horizontal fans on most of the ...   Sep 7 2009, 04:27 PM
Dr Evil   I have never seen the spring tension type and I ha...   Sep 7 2009, 11:39 AM
Vacca Rabite   Also, make sure that what ever you do leaves you w...   Sep 7 2009, 04:38 PM
r_towle   Also, make sure that what ever you do leaves you ...   Sep 7 2009, 04:57 PM
ClayPerrine   Also, make sure that what ever you do leaves you...   Sep 7 2009, 05:04 PM
Vacca Rabite   [quote name='r_towle' post='1211880' date='Sep 7 ...   Sep 8 2009, 07:20 AM
Rod   [quote name='r_towle' post='1211880' date='Sep 7...   Sep 8 2009, 08:36 AM
turboman808   Yup. This is how it looks (using Mike's engi...   Sep 8 2009, 12:54 PM
Rod   Thanks for all the help and information so far. I...   Sep 7 2009, 05:23 PM
Racer Chris   Thanks for all the help and information so far. ...   Sep 7 2009, 08:59 PM
DBCooper   The 911 fans are not the correct type of fan for h...   Sep 8 2009, 11:08 AM
lotus_65   it does look cool... i think of these :wub: but ...   Sep 7 2009, 07:09 PM
Racer Chris   That Corvair alternator location doesn't work ...   Sep 8 2009, 09:06 AM
Vacca Rabite   That Corvair alternator location doesn't work...   Sep 8 2009, 09:20 AM
ottox914   That Corvair alternator location doesn't work...   Sep 16 2009, 09:19 AM
Dr Evil   I think the sprung tensioner you were referring to...   Sep 8 2009, 12:00 PM
zymurgist   I find it interesting that a 2.7L 6cyl engine onl...   Sep 8 2009, 12:06 PM
Dr Evil   I find it interesting that a 2.7L 6cyl engine on...   Sep 8 2009, 07:34 PM
Dr Evil   More info from one of the vair forums: "Buy ...   Sep 8 2009, 12:04 PM
904svo   I like a vertical setup better, this is my version...   Sep 8 2009, 08:21 PM
Maltese Falcon   Downward airflow, and its equally channeled ductin...   Sep 8 2009, 09:34 PM
mskala   Downward airflow, and its equally channeled ducti...   Sep 9 2009, 11:53 AM
zymurgist   The engine RPM and fan RPM don't match linear...   Sep 9 2009, 12:17 PM
Nana's_914   The engine RPM and fan RPM don't match linea...   Sep 9 2009, 01:32 PM
mskala   The engine RPM and fan RPM don't match linea...   Sep 9 2009, 07:42 PM
Maltese Falcon   This is how the belt tensioner is situated on the ...   Sep 8 2009, 09:43 PM
DBCooper   The opposite should be true. At some point as the...   Sep 9 2009, 01:52 PM
jd74914   I would love to see a more conventional fan curve ...   Sep 9 2009, 02:34 PM
Type 4 Unleashed   :WTF:   Sep 10 2009, 01:47 AM
Jake Raby   They probably do.. I am doing some work with a gil...   Sep 10 2009, 04:16 PM
Rod   They probably do.. I am doing some work with a gi...   Sep 15 2009, 05:06 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:45 PM
