Hard starting when warm, 10-15 min/ stop 10 min/ hard to start |
Tom |
Sep 10 2009, 01:45 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
76 2.0 d-jet. stock displacement, hydraulics, with smog removed and backdated exhaust to 74 2.0 SSI's with Triad.
Runs great. Pulls hard to redline in 4th with no missing. Idles 850-950 when warm. Starts up when cold just great and idles 700-800. After running 10-15 minutes to town and going in the store for 10-15 minutes, come back out and turns over but doesn't want to fire. Pedal to the floor and turn over for 30-40 seconds and it gets faster and faster and finally fires up. Then runs great. If it sets for an hour or more , no problem in firing right up. Searched here and the only thing I can see that may be causing this is the distributor plate spring(s)? The wiring is all fairly new, so I don't think that would be the problem. Checked all of the connections and they are clean and tight. If the dist plate is sticking in the full advance would that give me these symptoms and how would I fix that? Grease? Special type? Thanks for any help, Tom |
Tom |
Sep 11 2009, 01:59 PM
Read somewhere in another thread about that helping sometimes. First time I had the problem, it wouldn't fire, so I pressed the pedal to the floor and sure enough it fired after about 10-15 seconds of cranking. ??? Don't understand why, but it has worked for me several times.
Thought of something lese to try this weekend to narrow the problem down. I'll take a small can of carb cleaner with me. If the problem shows up, I'll spray a little in the intake mouth of the cleaner. If it starts, then it must be fuel related. Make sense to you guys? Tom |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:17 AM |
