hydraulic clutch conversion |
jpnovak |
Sep 19 2009, 08:50 PM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
I just bought my first 914. I have had several early 911s and know my way around these cars.
The 914 will get an engine swap. It is being built as a GRM $2010 Challenge car. The car will then function as a DE car and potential DD if I can get the AC to work. There will be more details in another thread. has anyone converted to a hydraulic clutch setup? The swap will not run through a 901 box. Non-Porsche parts going in. Yeah, i will make some purists cry. Don't worry, its a flat four but it is water cooled. The slave cylinder is mounted to the drivetrain. I suppose I could go with a Tilton/Wilwood dual pedal setup. This should be easy to implement yet there are problems. Usually, the MC setup will not fit in the pedal area of a 911/914. The floor pedal sections are not too much different in terms of roominess. just looking for suggestions. |
IronHillRestorations |
Sep 20 2009, 09:44 AM
I. I. R. C. Group: Members Posts: 6,730 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You'll spend no less than 20% of your $2010 budget on a hydraulic clutch set up. No cheap way to do it.
My set up used a 928 master cylinder and a CNC slave, with the braided stainless flex lines for the fluid run through the clutch tube. It requires a custom mount for the slave and master cyl, and modifications to the clutch pedal to actuate the m/c. |
Lo-Fi Version | Time is now: 8th June 2024 - 03:20 PM |
