hydraulic clutch conversion |
jpnovak |
Sep 19 2009, 08:50 PM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
I just bought my first 914. I have had several early 911s and know my way around these cars.
The 914 will get an engine swap. It is being built as a GRM $2010 Challenge car. The car will then function as a DE car and potential DD if I can get the AC to work. There will be more details in another thread. has anyone converted to a hydraulic clutch setup? The swap will not run through a 901 box. Non-Porsche parts going in. Yeah, i will make some purists cry. Don't worry, its a flat four but it is water cooled. The slave cylinder is mounted to the drivetrain. I suppose I could go with a Tilton/Wilwood dual pedal setup. This should be easy to implement yet there are problems. Usually, the MC setup will not fit in the pedal area of a 911/914. The floor pedal sections are not too much different in terms of roominess. just looking for suggestions. |
ghuff |
Sep 21 2009, 07:23 PM
This is certainly not what I expected down here. Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
Wow that pedal setup rules.
How hard was the install? Can you go into more detail? What did you do to the throttle pedal there? |
stewteral |
Sep 24 2009, 08:37 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Wow that pedal setup rules. How hard was the install? Can you go into more detail? What did you do to the throttle pedal there? hey GHUFF, My first question is what are you trying to achieve with all the work and cost? In my case, I built the car up from a BARE mnocoque with a full V8 conversion and changed EVERYTHING! If you are running a 411 or 911 motor, cable is cheap and easy and you will only need to replace the cable every few years. (BTW: can you drive your car home when that cable breaks?: start the car in 1st gear and then shift as though you are double-clutching. I've driven 90 miles this way to get home.) For the BRAKES: I HATED the spongy stock brakes because of the proportioning valve mounted on the engine firewall. Having driven REAL race cars, I HAD to have the dual-master cyl/balance bar setup w/ Aeroquip flex-lines as they gave me a ROCK HARD pedal that hardly moves: it just makes the brakes work. OK to answer your question: first, to get into this kind of fabrication you need access to important tools like steel cutting, drilling and welding. For me, when I spent the $400 for a wire-feed welder w/ gas, it was an amazing break-through! I could not only create strong reliable welds, but the ability to hold a part and tack-weld became vital. To mount the pedals in a 914 (assuming you are 6' tall or less) is very easy as they will fit down in the footwell and still leave you enough legroom to drive. The stock sheet metal floor is too thin to take the loads, so I layed out a 3/16" thick sheet that I designed to bolt to the floor. I simply mounted the master cylinders to the plate and then bolt the plate (with spacers for the bolt heads) to the car. If you use 1/4" plate or thicker, you could simply drill that tap the master cylinder mounting holes allowing the plate to bolt flush to the floor. On the underside of the car, be sure to back up the plate mounting bolts with large diameter washers. The goal is spreading the load! I could have WELDED the plate, but I wanted the flexibility for later changes and bolting works fine. For Brake lights, I took the stock wires and ran them to a "micro-switch" wired "normally open" and then ran simple "ball-chain" to the pedal. I used a small piece of aluminum angle to make a mounting bracket. Thus, when the brake is NOT used, the switch is held in the OPEN position, but as soon as I push the brake and slack the chain, the switch closes. You can find the switch at Radio Shack and the "ball-chain" will be at most any hardware store. Next step is to run brake lines to the brakes. As our cars are AT LEAST 33 years old, I highly recommend replacing ALL the hard brake lines. Since I changed everything over to American thread (Wilwood cylinders, calipers and clutch stuff) it was very easy. You have a choices: you can put in new metric lines to the Wilwwod cylinders and flare the tube with an American end (Flaring tools are not expensive---see Harbor Freight) or you can go American all the way and just use an American-Metric adapter at the German calipers. American brake line is CHEAP!!: 4-ft sections are only around $6 from NAPA. A poor-boy approach would be using a "coupler" to splice from the old lines to a new piece to the master cylinder. Back to the master cylinders: I bought the set with the REMOTE reservoirs. The reservoirs easily mount under the front hood behind the gas tank and not gives you a LOT OF FLUID, but the reservoirs are easy to see for fluid level and filling. without SPILLING!!! As far as the throttle goes, I chose to change the angle of the throttle so it was sit next to the brake pedal in the right place for Heel-and-Toe braking & downshifting. Also, since I have a bunch of HP underfoot, I wanted to SLOW the opening of the throttle and all of this was achieved by lengthening the stock throttle arm ABOVE where the standard throttle cable attaches and then making a longer push-rod the the throttle pedal. The only other thing I did was create a very positive throttle STOP as I had a couple heart-stopping occasions where the throttle stuck OPEN by hanging up on the old stop. It was the 1st time that I found I had MORE HP than I had brakes to slow the car down. In one case, I was just about to end up in someone's living room! You may notice the black tube looping around the throttle: I copied this from a NASCAR throttle as it will allow me to PULL the throttle closed. when needed. If you have less than 300 HP, this is not necessary. So did I give you enough info? Do you have the tools available....or maybe a very skilled bud? Actually the DOING is more about CONFIDENCE with a proper goal in mind, than skill. Let me know if you have any more questions. BTW: I HIGHLY RECOMMEND reading the Carroll Smith books!! Start with "Prepare to Win", then "Drive to Win" and follow on through his series. They are racer bibles! Best, Terry |
Lo-Fi Version | Time is now: 8th June 2024 - 02:29 PM |
