Oil Pressure Sender Install, Thread Sealant? |
kconway |
Sep 25 2009, 12:26 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I need to put in a new oil pressure sender, I though I remember that it wouldn't work properly if you used teflon tape on the threads. Is this true? Do you install this dry?
Kev |
IronHillRestorations |
Sep 25 2009, 01:52 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I use a small amount of permatex aircraft sealant. They are tapered threads (dimensionally the same as 1/4" NPT) so in theory they should seal when you tighten them, the problem is when the bore has had a sender over tightened.
Lo-Fi Version | Time is now: 10th June 2024 - 05:13 AM |
