Rear Swaybar ---what should i expect?, stock swaybar being installed |
budman5201 |
Sep 22 2009, 06:11 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
Hey guys just wanted some info. I have the front swaybar installed and i am installing the rear this weekend....What will my difference in handling be compared to running a front only swaybar? ( i am very used to swaying the back end out around corners and controlling it with my 252 hp subie.)
Just wondering the in the pants difference? (IMG:style_emoticons/default/driving.gif) |
budman5201 |
Sep 26 2009, 05:17 PM
Hey Andy does your car weight more than mine. Mine is stock weight. Basically lost about 35 lbs in weight for my subaru engine, and gained about 35 lbs in front and underneath from radiator and water in lines. So definately not heavy by any means.
I have bilsteins all the way around, stock spring weight i think (yellow springs in back cant tell if they were painted) I think i am liking the stock swaybar in the back. I havent done much high speed testing though. |
SirAndy |
Sep 26 2009, 05:23 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Hey Andy does your car weight more than mine. Mine is stock weight. Nope, i'm down to just under 2000lbs, so mine's a bit lighter than stock. QUOTE I think i am liking the stock swaybar in the back. I havent done much high speed testing though. Don't!!! I mean the high speed testing. (IMG:style_emoticons/default/biggrin.gif) Get on a skid-pad (or parking lot) and test the balance at LOW speed. If the car is tail-happy now, you don't want to find that out at 80mph! (IMG:style_emoticons/default/driving.gif) Andy |
budman5201 |
Sep 28 2009, 07:18 PM
Hey Andy does your car weight more than mine. Mine is stock weight. Nope, i'm down to just under 2000lbs, so mine's a bit lighter than stock. QUOTE I think i am liking the stock swaybar in the back. I havent done much high speed testing though. Don't!!! I mean the high speed testing. (IMG:style_emoticons/default/biggrin.gif) Get on a skid-pad (or parking lot) and test the balance at LOW speed. If the car is tail-happy now, you don't want to find that out at 80mph! (IMG:style_emoticons/default/driving.gif) Andy I kinda like the bar, its very flat in the corners now. And YES i did low speed testing. It looks like maybe i have higher spring rates just like you. How can i tell what i got if someone in the past painted them yellow to match the bilsteins. ? The only way i can break it loose around a turn is touch the boost and it drifts but a very controlled drift (unlike before). thanks guys for your help.... |
Lo-Fi Version | Time is now: 10th June 2024 - 12:24 AM |
