hydraulic clutch conversion |
jpnovak |
Sep 19 2009, 08:50 PM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
I just bought my first 914. I have had several early 911s and know my way around these cars.
The 914 will get an engine swap. It is being built as a GRM $2010 Challenge car. The car will then function as a DE car and potential DD if I can get the AC to work. There will be more details in another thread. has anyone converted to a hydraulic clutch setup? The swap will not run through a 901 box. Non-Porsche parts going in. Yeah, i will make some purists cry. Don't worry, its a flat four but it is water cooled. The slave cylinder is mounted to the drivetrain. I suppose I could go with a Tilton/Wilwood dual pedal setup. This should be easy to implement yet there are problems. Usually, the MC setup will not fit in the pedal area of a 911/914. The floor pedal sections are not too much different in terms of roominess. just looking for suggestions. |
andys |
Sep 29 2009, 10:03 AM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Jamie,
If you're not building a track car, then perhaps you can approach a hydraulic clutch as I did (depending on your fabrication skill level). I ran linkage from the stock clutch lever to a bellcrank system with a Wilwood clutch master. My center console will hide the master from view. Andys Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 01:57 PM |
