| Jakeodoule |
Oct 1 2009, 11:53 AM
Member ![]() ![]() Group: Members Posts: 353 Joined: 10-October 08 From: Des Moines Iowa Member No.: 9,630 Region Association: Pacific Northwest |
If this is in the wrong place, sorry.
I installed they're fuel lines last night and I must say it is a great product. It beats the hell out of trying to get the right bend on some brake lines. Plus they are stainless. They went right in according to directions and the bends are perfect. I had my motor out already but I could see doing it with the engine in place no problem. They are a bit $pendy, but if you were bending them yourself from brake tubing I could see spending a ton of time to get them right. Also whats your car worth after all the time and money you put into it. a 150 bucks is not alot of money if its burning on the side of the road.... I think the engine compartment lines could be a bit longer to reach down around the corner of the hell hole but overall I give them an A+ Thanks and I will now drive without worrying about the plastic fuel lines. |
| Vysoc |
Oct 1 2009, 03:12 PM
Vysoc ![]() ![]() ![]() Group: Members Posts: 589 Joined: 27-August 09 From: NorthWest Arkansas Member No.: 10,737 Region Association: Southwest Region |
Once the stainless steel lines are in place they are set in there quite nicely and tight. There is a fairly substantial tab under the shifter that is folded over them and they fit in perfectly. Remember they run through a very thick piece of rubber grommet in the front firewall and grommets in the back and lay perfectly against the right side of the tunnel. The bends in the stainless are perfect they are quite stable.
Vysoc |
| JeffBowlsby |
Oct 1 2009, 03:41 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,203 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
That actually describes my question and concern perfectly.
With the sheet metal tabs simply bent around them, its metal to metal in a vibration environment. At some point (OK, OK, it may be a long time, bt still...)the metal will wear through due to friction, the location may rattle becasue the metal tabs open up just ever so slightly. I would think these connections would be best to isolate at contact points with some kind of tape, rubber isolator or similar. Also if they 'lay perfectly against the right side of the tunnel', are the fuel line surfaces in light contact with the chassis?...and if they are in contact, do they rattle to teh chassis when going over bumps? What has been peoples experience that have had them installed for awhile? Once the stainless steel lines are in place they are set in there quite nicely and tight. There is a fairly substantial tab under the shifter that is folded over them and they fit in perfectly. Remember they run through a very thick piece of rubber grommet in the front firewall and grommets in the back and lay perfectly against the right side of the tunnel. The bends in the stainless are perfect they are quite stable. Vysoc |
Jakeodoule Review of Tangerine's stainless fuel lines. Oct 1 2009, 11:53 AM
zymurgist Cool review! I spent a lot of time bending th... Oct 1 2009, 11:59 AM
Jakeodoule just go to they're site for pics and pricing.
... Oct 1 2009, 12:24 PM
zymurgist
just go to they're site for pics and pricing.... Oct 1 2009, 12:55 PM
Vysoc
I installed... Oct 1 2009, 12:41 PM
Jeff Bowlsby Do these metal lines bang together especially in t... Oct 1 2009, 02:32 PM
Jakeodoule I would think they wouldn't bang around. There... Oct 1 2009, 02:48 PM
tat2dphreak
I put in aluminum racing lines from Summit, Jef... Oct 1 2009, 02:50 PM
neil30076
Also if they 'lay perfectly against the righ... Oct 1 2009, 03:56 PM
Racer Chris
At some point (OK, OK, it may be a long time, bt... Oct 1 2009, 05:47 PM
bperry
At some point (OK, OK, it may be a long time, b... Oct 2 2009, 07:46 PM
iamchappy No need to review as they are fabulous..... Oct 1 2009, 05:34 PM
Cevan Mine have been in for 7000 miles of New England dr... Oct 1 2009, 06:02 PM
bandjoey With the tough new rubbers, why not just run rubbe... Oct 1 2009, 07:27 PM
oh no, not again! Thanks for the review Jake! Now I know my effo... Oct 2 2009, 10:50 AM
2-OH! Jeff:
I used the SS lines as well, but I sliced a... Oct 2 2009, 05:47 PM
ClayPerrine I have done the lines in my car from scratch, usin... Oct 2 2009, 09:45 PM
Gigamight Thanks for the thumbs up on this product. I have b... Oct 3 2009, 11:38 AM
Jakeodoule
Thanks for the thumbs up on this product. I have ... Oct 3 2009, 01:00 PM
rhodyguy jeff, if you put the little black pieces of plasti... Oct 3 2009, 01:20 PM
Sparky I've had the opportunity to see a lot of the p... Oct 3 2009, 11:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th March 2026 - 11:11 PM |
