| TravisG |
Oct 2 2009, 05:21 PM
Member ![]() ![]() Group: Members Posts: 71 Joined: 8-June 09 From: Supply, NC Member No.: 10,449 Region Association: MidAtlantic Region |
Hi All,
My 73 914-4, just got on the road (IMG:style_emoticons/default/driving.gif) , will bottom the suspension in the rear when I take off in 1st gear quickly. It will also bottom out at speed if I go over a good size bump. At rest, It sits lower in the back than the front. OK, Now the question: Is it the springs, the shocks, or a combinations of the 2? The car is not bouncy when driving, just bottoms out when driven hard. Also where is the best place to get the springs or shocks? Thanks in Advance |
| SLITS |
Oct 2 2009, 09:40 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
You could reasonably test the springs with a known weight. Depending on who you want to argue with, they are either 90 lb/in or 100 lb/in. Generally black paint and one or two green stripes on one coil of the spring. This assumes the stock springs are still on and haven't been changed.
If the trailing arms bushings are worn out, the inner trailing arm mount ovaled or inner mount nut loose .... you'll get some banging around .... and if loose enough, some exciting handling. So, if you place 90 lbs on top of the spring, it should depress one inch. |
| srb7f |
Oct 2 2009, 10:19 PM
Member ![]() ![]() Group: Members Posts: 157 Joined: 17-May 04 From: Roswell, GA Member No.: 2,077 Region Association: None |
I find it hard to believe that your car truly bottoms out as you have described.
There lots of things that move when the car does the things you describe, and all of them could make noise. Start simple, with the trailing arms and the bushings between them and the body. Check the status of your rear wheel bearings for excessive play in and out. Check the upper and lower shock bolts. I would also check the status of your CV joints. Buy a bunch of CV grease, then take off the half-axle shafts, disassemble, and check the inside of the CV joint for deep pits. Re-pack them if they look OK, but replace if they have deep pits worn in them on the inside of the grooves for the bearings. If one of them lets go completely, you won't be able to drive the car. It's a little hard to describe, but I believe the Haynes manual explains it fairly well. It'll be pretty easy to see once you get them apart. |
| benalishhero |
Oct 3 2009, 06:20 PM
Member ![]() ![]() Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
I find it hard to believe that your car truly bottoms out as you have described. There lots of things that move when the car does the things you describe, and all of them could make noise. Start simple, with the trailing arms and the bushings between them and the body. Check the status of your rear wheel bearings for excessive play in and out. Check the upper and lower shock bolts. I would also check the status of your CV joints. Buy a bunch of CV grease, then take off the half-axle shafts, disassemble, and check the inside of the CV joint for deep pits. Re-pack them if they look OK, but replace if they have deep pits worn in them on the inside of the grooves for the bearings. If one of them lets go completely, you won't be able to drive the car. It's a little hard to describe, but I believe the Haynes manual explains it fairly well. It'll be pretty easy to see once you get them apart. Mine bottomed out until I replaced original springs ,so it's possible. |
TravisG Rear end Bottoming out. opinions? Oct 2 2009, 05:21 PM
SLITS Springs or if you have adjustable perches they are... Oct 2 2009, 05:30 PM
TravisG Not much camber on the rear wheels, would have to... Oct 2 2009, 06:04 PM
TravisG seems my pic didn't post :confused: once I... Oct 2 2009, 06:09 PM
Sleepin Take all the coke out of the trunk! :blink:
... Oct 2 2009, 05:43 PM
SLITS
... Oct 2 2009, 05:48 PM
Sleepin I don't know whose car this is, but maybe I sh... Oct 2 2009, 05:54 PM
SLITS
I don't know whose car this is, but maybe I s... Oct 2 2009, 05:57 PM
r_towle go jogging...
Rich Oct 2 2009, 06:02 PM
Sleepin Read this thread on how to post a pic Travis:
htt... Oct 2 2009, 06:11 PM
TravisG http://i583.photobucket.com/albums/ss278/TravisGEl... Oct 2 2009, 06:30 PM
SLITS That looks like about stock stance for a Teener ..... Oct 2 2009, 06:42 PM
Sleepin I would dial down the front height as well! Oct 2 2009, 07:11 PM
lynn478co
... Oct 2 2009, 07:30 PM
TravisG Motor mounts and trans mounts are all new. Just p... Oct 2 2009, 08:08 PM
TravisG I replaced all the cv joints and the boots when I ... Oct 3 2009, 05:11 PM
SLITS
Is there a practical and simple way to lower the ... Oct 3 2009, 08:29 PM
TravisG It's done with the adjustor screws on the end ... Oct 3 2009, 08:44 PM
SGB If you think the springs are original, then they a... Oct 2 2009, 10:09 PM
campbellcj If you lower the front using the adjuster screws, ... Oct 3 2009, 09:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 12:31 AM |
