| TravisG |
Oct 2 2009, 05:21 PM
Member ![]() ![]() Group: Members Posts: 71 Joined: 8-June 09 From: Supply, NC Member No.: 10,449 Region Association: MidAtlantic Region |
Hi All,
My 73 914-4, just got on the road (IMG:style_emoticons/default/driving.gif) , will bottom the suspension in the rear when I take off in 1st gear quickly. It will also bottom out at speed if I go over a good size bump. At rest, It sits lower in the back than the front. OK, Now the question: Is it the springs, the shocks, or a combinations of the 2? The car is not bouncy when driving, just bottoms out when driven hard. Also where is the best place to get the springs or shocks? Thanks in Advance |
| campbellcj |
Oct 3 2009, 09:02 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,702 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
If you lower the front using the adjuster screws, make sure you keep the number of turns as close to identical as possible, side to side.
TravisG Rear end Bottoming out. opinions? Oct 2 2009, 05:21 PM
SLITS Springs or if you have adjustable perches they are... Oct 2 2009, 05:30 PM
TravisG Not much camber on the rear wheels, would have to... Oct 2 2009, 06:04 PM
TravisG seems my pic didn't post :confused: once I... Oct 2 2009, 06:09 PM
Sleepin Take all the coke out of the trunk! :blink:
... Oct 2 2009, 05:43 PM
SLITS
... Oct 2 2009, 05:48 PM
Sleepin I don't know whose car this is, but maybe I sh... Oct 2 2009, 05:54 PM
SLITS
I don't know whose car this is, but maybe I s... Oct 2 2009, 05:57 PM
r_towle go jogging...
Rich Oct 2 2009, 06:02 PM
Sleepin Read this thread on how to post a pic Travis:
htt... Oct 2 2009, 06:11 PM
TravisG http://i583.photobucket.com/albums/ss278/TravisGEl... Oct 2 2009, 06:30 PM
SLITS That looks like about stock stance for a Teener ..... Oct 2 2009, 06:42 PM
Sleepin I would dial down the front height as well! Oct 2 2009, 07:11 PM
lynn478co
... Oct 2 2009, 07:30 PM
TravisG Motor mounts and trans mounts are all new. Just p... Oct 2 2009, 08:08 PM
SLITS You could reasonably test the springs with a known... Oct 2 2009, 09:40 PM
srb7f I find it hard to believe that your car truly bott... Oct 2 2009, 10:19 PM
TravisG I replaced all the cv joints and the boots when I ... Oct 3 2009, 05:11 PM
SLITS
Is there a practical and simple way to lower the ... Oct 3 2009, 08:29 PM
TravisG It's done with the adjustor screws on the end ... Oct 3 2009, 08:44 PM
benalishhero
I find it hard to believe that your car truly bot... Oct 3 2009, 06:20 PM
SGB If you think the springs are original, then they a... Oct 2 2009, 10:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 12:31 AM |
