Transmission gearing advice needed, I have some choices to make |
DNHunt |
Oct 4 2009, 08:43 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
2380 Type IV, redline at 7000. Best power from about 3600 to about 6200. Street car some AX. 205 15 tires street and R compound. With the stock box on the AX courses we run 3rd is just too tall so I know I want a shorter 3rd. ZD 5th is just right or a little low for the highway so I don't want to change that. So I can change 3rd and 4th.
I tore down a 902/02 tranny and got M, S, X and I have N, V, ZD from the stock box. I'm tempted to build a A, F, M, S, ZD box. I could build a A, F, M, V, ZD box. To complicate it more I know where there is a brand new L gear with hub. I am really tempted to build a A, F, L, S, ZD box. I think it makes the most sense to stretch from 4th to 5th. What do you think? Dave |
DNHunt |
Oct 4 2009, 09:51 AM
Ah JP, my favorite adviser. You always give me good advise. The only bad advise I've ever got from you is the advise I haven't listened to.
I hadn't thought about the GA main shaft but, looking at the guts and doing a little figuring I see you can change input shafts without changing pinion shafts so pinion depth doesn't need to be reset. I'll have to ponder. I always short shift to second. I've also considered launching in second cause that dogleg shift is slow. F would be better for that. Dave |
Lo-Fi Version | Time is now: 9th June 2024 - 11:45 PM |
