Rear Bumpertops Finally! After alot of trial and error, Prepurchse closed |
Mikey914 |
Sep 27 2009, 11:59 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
For those of you that hjave been following the production of the rear tops, I have finally got all the bugs worked out. I kept having the interal stainless structure blow into the top edge at the licence plate wells. I'm having to play with the water jet cutter to make the shape I need to make this work correctly. These do have the suport running from the edge mounts through the center mount so the section will not droop where the licence plate goes.
After the run is started these will go to $286 Who needs one? Don't need money now, just a list of those that will be needing them, I'll forward out the payment specifics later. Attached thumbnail(s) |
Mikey914 |
Oct 5 2009, 12:00 AM
Added the first good production bumper to the classified area.
Lo-Fi Version | Time is now: 1st June 2024 - 08:54 AM |
