How much fuel should flow?, Out of fuel pump with EFI |
Rocky |
Oct 4 2009, 07:27 PM
From the cockpit Group: Members Posts: 341 Joined: 24-March 04 From: Gig Harbor,WA Member No.: 1,845 |
My super reliable 75' 1.8 now will not start. It has stock injection. I do have spark! Injectors show no fuel outflow when cranked. I then went to the pump and when cranking over it shows a steady low flow of fuel. Shouldent I see a pretty high rate of pressurized fuel given these are putting out over 20 psi? This is the original fuel pump.
I know I havent posted in a while... Im a looser (IMG:style_emoticons/default/wacko.gif) Rocky |
Rocky |
Oct 4 2009, 08:33 PM
If I assume fuel flow is adequate out of pump but no fuel out of injectors when engine is cranked, any idea next area(s) to check?
Thanks! |
davesprinkle |
Oct 5 2009, 10:47 AM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
If I assume fuel flow is adequate out of pump but no fuel out of injectors when engine is cranked, any idea next area(s) to check? Thanks! The Ljet brain uses the coil signal to generate the fuel injector pulses. Make sure that the lead to the coil is still attached. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:26 AM |
