> 74 2.0L, Running Very Rich, owner quite confused, need diagnostic help
drumsticks2112
post Sep 20 2009, 12:56 PM
Car fires without a problem, but idles quite rough, and runs very rich, so much so that when the it settles down to normal idles, it floods out. MPS was replaced with a used but tested one recently. When it was last running ( a year ago) it ran a little rich, but nothing like this.
As of now, the CHT is not connected. When it is connected, the RPMs jump up to 4000 and stay there. When the CHT is bypassed with direct grounding of the harness, the results are the same as with the sensor being disconnected.
I have no reason to suspect the injectors, FPR, Decel Valve, or the MPS.
Any and all advice is welcome.
-Todd
Rand
post Oct 6 2009, 10:52 AM
Cross Member
I just pulled the line off the CSV and plugged it... A pin that fit tightly and clamped.
drumsticks2112   74 2.0L, Running Very Rich, owner quite confused   Sep 20 2009, 12:56 PM
type47   I thought the CHT had to be connected to run; must...   Sep 20 2009, 04:12 PM
Rand   Running that rich makes me suspect the MPS (even t...   Sep 20 2009, 04:18 PM
Dave_Darling   Disconnecting the CHT will send the mixture very r...   Sep 20 2009, 04:53 PM
pilothyer   I didn't think an open CHTS would allow the ca...   Sep 20 2009, 05:15 PM
underthetire   I had a CHT go bad. Went open when hot. Biatch to ...   Sep 21 2009, 10:04 AM
CHAZT54   I am working with drumsticks on this car and have ...   Sep 23 2009, 12:41 PM
greenie   I am working with drumsticks on this car and have...   Sep 23 2009, 07:41 PM
Dave_Darling   ...At the same time I connected the hd temp sensor...   Sep 23 2009, 08:51 PM
tod914   Did you actually test the MPS to see if it holds v...   Sep 23 2009, 07:56 PM
drumsticks2112   Did you actually test the MPS to see if it holds ...   Sep 23 2009, 10:09 PM
Bleyseng   does sound like a vacuum leak of misplaced hose to...   Sep 23 2009, 10:07 PM
tod914   Compliments of Dave. http://www.pelicanparts.com/...   Sep 23 2009, 10:26 PM
drumsticks2112   Compliments of Dave. http://www.pelicanparts.com...   Sep 23 2009, 10:58 PM
CHAZT54   [quote name='tod914' post='1218012' date='Sep 23 ...   Sep 30 2009, 12:47 PM
Van914   Did you check the adjustment on the FI Brain. I us...   Sep 30 2009, 01:13 PM
rjames   Did you check the adjustment on the FI Brain. I u...   Sep 30 2009, 01:36 PM
drumsticks2112   Thanks for the additional ideas guys, here is the ...   Sep 30 2009, 04:22 PM
r_towle   Start at the beginning. Remove EVERY vacuum line f...   Sep 30 2009, 03:39 PM
Rand   Like Dave said, idle that fast means there HAS to ...   Sep 30 2009, 03:39 PM
r_towle   no idea what an FPS is nor a TVS. The MPS does not...   Sep 30 2009, 04:33 PM
drumsticks2112   no idea what an FPS is nor a TVS. The MPS does no...   Sep 30 2009, 09:57 PM
Dave_Darling   The MPS has a mechanical component. If you shake ...   Sep 30 2009, 11:11 PM
CHAZT54   OK - we took your advice and dismantled the intake...   Oct 2 2009, 07:52 AM
r_towle   There is no fuel pressure sensor...a fuel pressure...   Oct 2 2009, 01:13 PM
CHAZT54   There is no fuel pressure sensor...a fuel pressur...   Oct 2 2009, 03:42 PM
CHAZT54   There is no fuel pressure sensor...a fuel pressu...   Oct 5 2009, 12:21 PM
r_towle   [quote name='CHAZT54' post='1221175' date='Oct 2 ...   Oct 5 2009, 04:48 PM
CHAZT54   [quote name='CHAZT54' post='1221175' date='Oct 2...   Oct 6 2009, 07:47 AM
r_towle   [quote name='r_towle' post='1222305' date='Oct 5 ...   Oct 6 2009, 01:18 PM
r_towle   You will need an inline gauge to confirm how the F...   Oct 2 2009, 04:51 PM
Rand   I just pulled the line off the CSV and plugged it....   Oct 6 2009, 10:52 AM
CHAZT54   EUREKA!! It finally runs & idles norma...   Oct 8 2009, 12:27 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:14 AM
