sm32589g |
Newbie ![]() Group: Members Posts: 6 Joined: 5-October 09 From: Washington Member No.: 10,889 Region Association: None ![]() |
hello i just wanted to say hi as i will likely be on this forum from now on. I am a bmw fanatic that just recently purchased a 914. with plans on converting it to a 6 and using it for track purposes. i am knowledgeable about bmw's but when it comes to porsches i know nothing! so please forgive me in advance thank you (IMG:style_emoticons/default/smile.gif)
Grngoat |
Lurker Member ![]() ![]() Group: Members Posts: 158 Joined: 17-October 04 From: Fort Worth, TX Member No.: 2,967 Region Association: Southwest Region ![]() |
I see you found it to the world. Welcome.
I run a 901 behind my 3.6. Andy does the same on his. That's the cheapeast, easiest option, but you do have to be easy on first gear. So far it's surviived for about 20,000 miles and a dozen or so autocrosses. I did have a bearing fail in the trans, but who knows if that was just old age are not. Otherwise, it is okay. A 915 is a little harder to do, but not that bad - just more $. A 930 is more money and bulletproof. A G-50 is quite a bit more involved. I don't know of anyone ever having done it, really. I know that Clay Perrine is planning to, and I will eventually, but there is a lot of work involved there. You have to run the transmission inverted because you can't flip the ring gear, and that interfere's with the rear trunk floor. Shift linkage is all different. Yada, yada. A 3.2 with a 901 would be great. You can always upgrage the trans later. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:19 AM |
