| kenshapiro2002 |
Oct 7 2009, 05:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,486 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
For those who have been following my travails to get this beast running correctly (had a bad rotor), well, it's still running like crap. In fact it stalled out twice today and I wasn't sure Id make it back home from around the block. So, I just decided to dive in and have removed one of the 40s just now. I'm taking photos, counting turns and taking my good old time. I'll let ya'll know what happens.
| SGB |
Oct 8 2009, 10:40 AM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
The tabs that hold the float pivot inside break easily.
kenshapiro2002 Newbie Tears Into Webers Oct 7 2009, 05:01 PM
neil30076
For those who have been following my travails to ... Oct 7 2009, 05:08 PM
r_towle It was inevitable.
Here is a reference pic for the... Oct 7 2009, 05:08 PM
neil30076
It was inevitable.
Here is a reference pic for th... Oct 7 2009, 05:10 PM
r_towle
It was inevitable.
Here is a reference pic for t... Oct 7 2009, 05:21 PM
kenshapiro2002 I didn't need to chsange anything on my linkag... Oct 7 2009, 07:18 PM
kenshapiro2002 Why's id the vacuum advance jet circled and re... Oct 7 2009, 07:17 PM
kenshapiro2002 Needless to say, my Weber manual is a little diffe... Oct 7 2009, 07:22 PM
r_towle The best way to do it is to remove everything.
Acc... Oct 7 2009, 07:30 PM
neil30076 Ken, check out http://www.rescue912.com/spider/Web... Oct 7 2009, 07:46 PM
kenshapiro2002 Thanks.
Ken, check out http://www.rescue912.com/... Oct 7 2009, 08:06 PM
kenshapiro2002 Thanks guys. Some questions:
1.) The one part I m... Oct 7 2009, 08:06 PM
neil30076
"Note which way round (freakin' Brits) t... Oct 7 2009, 08:16 PM
SGB 1. no big deal. it will be apparent
2. use the n... Oct 8 2009, 07:45 AM
kenshapiro2002 Thanks. When you talk about the tabs breaking, are... Oct 8 2009, 07:51 AM
kenshapiro2002 RE: Newbie Tears Into Webers Oct 7 2009, 08:39 PM
kenshapiro2002 RE: Newbie Tears Into Webers Oct 7 2009, 08:40 PM
kenshapiro2002 RE: Newbie Tears Into Webers Oct 7 2009, 08:42 PM
kenshapiro2002 First two shots were before I sprayed the outsides... Oct 7 2009, 08:42 PM
Vacca Rabite Mmmmmmm goooey.
Keep track of all the hardware an... Oct 8 2009, 07:20 AM
kenshapiro2002 Thanks. Know any of the answers to post #11 above?... Oct 8 2009, 07:25 AM
kenshapiro2002 So...how come the Weber rebuild kits come with fou... Oct 8 2009, 11:07 AM
neil30076
So...how come the Weber rebuild kits come with fo... Oct 8 2009, 11:25 AM
kenshapiro2002 Neil,
What "thick phenolic spacer"? Whe... Oct 8 2009, 12:22 PM
neil30076
Neil,
What "thick phenolic spacer"? Wh... Oct 8 2009, 12:56 PM
SGB
[quote name='kenshapiro2002' post='1223481' date=... Oct 8 2009, 01:45 PM
kenshapiro2002 Yeah...but I was asking about the gaskets that com... Oct 8 2009, 02:49 PM
kenshapiro2002 I'm clueless on what you're referring to a... Oct 8 2009, 02:51 PM
jmill 2.) How come the rebuild kit comes with a new need... Oct 8 2009, 01:26 PM
kenshapiro2002 Gotcha. Just wondering why they have it in the reb... Oct 8 2009, 01:30 PM
kenshapiro2002 Hmmmmmm...aircooled.com says to use the thicker ph... Oct 8 2009, 02:58 PM
neil30076
Hmmmmmm...aircooled.com says to use the thicker p... Oct 8 2009, 03:13 PM
tat2dphreak use the same damn ones... thick :)
if not you wi... Oct 8 2009, 03:58 PM
r_towle Show a pic of the gaskets.
Weber rebuild kits are ... Oct 8 2009, 05:16 PM
kenshapiro2002 Called Weber Direct and the guy said they throw in... Oct 8 2009, 05:49 PM
kenshapiro2002 The cleaner is supposed to be kept off skin, but n... Oct 8 2009, 05:47 PM
r_towle
The cleaner is supposed to be kept off skin, but ... Oct 8 2009, 05:50 PM
kenshapiro2002 I believe you once said to check the floats in gas... Oct 8 2009, 07:35 PM
Max914
The cleaner is supposed to be kept off skin, but ... Oct 11 2009, 06:09 PM
SGB You just don't want to get water into a leaky ... Oct 8 2009, 08:14 PM
kenshapiro2002 That's the tab I thought you meant...the end t... Oct 8 2009, 08:18 PM
r_towle I use gas, and yes....if you see bubbles, replace ... Oct 8 2009, 08:26 PM
kenshapiro2002 So...what's the reason for using gas? Oct 8 2009, 08:44 PM
r_towle Dunno, just seems logical
Rich Oct 8 2009, 08:51 PM
kenshapiro2002 Well, I tested my floats in water. No fumes, no ne... Oct 12 2009, 10:41 AM
SGB :beer2: Oct 8 2009, 10:44 PM
r_towle So, how is it going? get lost yet?
Rich Oct 9 2009, 05:02 PM
neil30076
Rich
Yes, en... Oct 9 2009, 06:15 PM
SGB I'm checking back too... Oct 9 2009, 07:01 PM
tat2dphreak he blew up the garage testing the float in gas, di... Oct 9 2009, 08:22 PM
kenshapiro2002 Wasn't in a big rush because the gaskets for t... Oct 9 2009, 11:00 PM
Gint Believe me...I'll be posting every move.
I do... Oct 10 2009, 08:51 AM
kenshapiro2002 I've been told that my linkage is a good one, ... Oct 10 2009, 09:11 AM
kenshapiro2002 P.S. My best guess is that the carbs will not solv... Oct 9 2009, 11:00 PM
rhodyguy if the intake manifolds are still off of the engin... Oct 10 2009, 09:30 AM
kenshapiro2002 Good idea...thanks. Just checked and it's stra... Oct 10 2009, 09:54 AM
rhodyguy you need to figure out a better venting system. th... Oct 10 2009, 10:41 AM
kenshapiro2002 Gotcha...glad you noticed. Will something like the... Oct 10 2009, 11:19 AM
Gint I'll leave the venting question to the environ... Oct 10 2009, 11:42 AM
kenshapiro2002 I have no heating system, but do want to keep the ... Oct 10 2009, 12:00 PM
kenshapiro2002 Are the valve covers on these guys vented? Oct 10 2009, 12:27 PM
Gint No. The 2.0 have head vents, the 1.8's do not... Oct 10 2009, 01:04 PM
kenshapiro2002 4 bolt intake manifolds...a punched out 1.7 (1911c... Oct 10 2009, 06:34 PM
type47
... Oct 11 2009, 12:49 PM
Gint [quote name='Gint' post='1224282' date='Oct 10 200... Oct 11 2009, 04:03 PM
kenshapiro2002 Hey...who hijacked my "Newbie Rebuilding Webe... Oct 11 2009, 04:59 PM
Gint You'll get used to it. Oct 11 2009, 05:01 PM
kenshapiro2002 Already am! :D
Oct 11 2009, 05:28 PM
kenshapiro2002 8:24 EST...out to the garage to start putting the ... Oct 12 2009, 07:16 AM
kenshapiro2002 What pyrose do "starter valves" have (ch... Oct 12 2009, 08:23 AM
kenshapiro2002 pyrose = purpose
What pyrose do "starter v... Oct 12 2009, 08:23 AM
type47 Is "starter valve" a Weber thing? You... Oct 12 2009, 08:44 AM
kenshapiro2002 Yes...a Weber thing. 99% sure it's soe kinda c... Oct 12 2009, 08:57 AM
rhodyguy a couple of pumps on the throttle, start it up and... Oct 12 2009, 09:27 AM
kenshapiro2002 I just tried it and it didn't work. Oh yeah...... Oct 12 2009, 10:35 AM
jaxdream He maybe referring to the accelartor pumps on the ... Oct 12 2009, 09:54 AM
kenshapiro2002 Nah...and there's no "he"...it's... Oct 12 2009, 10:37 AM
kenshapiro2002 My float was at 8mm (with gasket on), instead of t... Oct 12 2009, 11:00 AM
r_towle
My float was at 8mm (with gasket on), instead of ... Oct 12 2009, 11:37 AM
kenshapiro2002 And my "drop" measurement (I understand ... Oct 12 2009, 11:11 AM
kenshapiro2002 Now...if it runs as well as it looks...
Any logi... Oct 12 2009, 12:46 PM
SirAndy Any logic in putting the rebuilt carb back in with... Oct 12 2009, 12:50 PM
kenshapiro2002 OK...thanks.
Any logic in putting the rebuilt c... Oct 12 2009, 01:01 PM
r_towle Just do the other one...then you will KNOW its don... Oct 12 2009, 01:09 PM
McMark I'm a little late to this thread, but my comme... Oct 12 2009, 01:31 PM
r_towle
I'm a little late to this thread, but my comm... Oct 12 2009, 03:04 PM
kenshapiro2002 Neither do I, but then again, he didn't say th... Oct 12 2009, 04:34 PM
kenshapiro2002 Idle - 50
Main - 115
AC Jet - 200
Emulsion Tubes ... Oct 12 2009, 01:44 PM
jmill I thought you went to 125 mains. Are you going ba... Oct 12 2009, 05:17 PM
kenshapiro2002 I bought the 125s, ran them for a few days and the... Oct 12 2009, 07:16 PM
neil30076
Whattaya mean by vent size?
:blink:
( ven... Oct 12 2009, 07:33 PM
kenshapiro2002 Oh...the auxiliary venturis! They are 28s. Hey... Oct 12 2009, 09:02 PM
Vacca Rabite
Oh...the auxiliary venturis! They are 28s. He... Oct 12 2009, 10:51 PM
URY914 When reinstalling the carb to the manifold, and th... Oct 12 2009, 07:37 PM
kenshapiro2002 I had tons of popping and backfiring. I'm usin... Oct 12 2009, 09:05 PM
jmill Washers find a way to drop into the intake and cau... Oct 12 2009, 09:12 PM
McMark :rotfl: You guys are funny. :lol4: Oct 12 2009, 09:34 PM
kenshapiro2002 See...if I just say "Thanks" (to your co... Oct 13 2009, 05:29 AM
jaxdream The fella is trying do solve some issues himself, ... Oct 13 2009, 12:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 05:03 AM |
