> Newbie Tears Into Webers
kenshapiro2002
post Oct 7 2009, 05:01 PM
For those who have been following my travails to get this beast running correctly (had a bad rotor), well, it's still running like crap. In fact it stalled out twice today and I wasn't sure Id make it back home from around the block. So, I just decided to dive in and have removed one of the 40s just now. I'm taking photos, counting turns and taking my good old time. I'll let ya'll know what happens.
SGB
post Oct 8 2009, 08:14 PM
just visiting
You just don't want to get water into a leaky float, then have it slowly creep back into the gas in the bowl.
I'm not a vendor, I did buy fuel line and fittings and venturis from aircooled,net.
The tabs I broke are the ones that HOLD the pin that the float pivots on (two in each carb next to the needle valve), not the little flat tab on the float assembly that contacts the needle valve (the one used to set the float height).
kenshapiro2002
post Oct 8 2009, 08:18 PM
That's the tab I thought you meant...the end that has the split in it...that the rod presses into.
My thought is, that if you submerged the float in water, and saw it was leaking (bubbles) wouldn't you replace it?
QUOTE(SGB @ Oct 8 2009, 10:14 PM) *
kenshapiro2002   Newbie Tears Into Webers   Oct 7 2009, 05:01 PM
neil30076   For those who have been following my travails to ...   Oct 7 2009, 05:08 PM
r_towle   It was inevitable. Here is a reference pic for the...   Oct 7 2009, 05:08 PM
neil30076   It was inevitable. Here is a reference pic for th...   Oct 7 2009, 05:10 PM
r_towle   It was inevitable. Here is a reference pic for t...   Oct 7 2009, 05:21 PM
kenshapiro2002   I didn't need to chsange anything on my linkag...   Oct 7 2009, 07:18 PM
kenshapiro2002   Why's id the vacuum advance jet circled and re...   Oct 7 2009, 07:17 PM
kenshapiro2002   Needless to say, my Weber manual is a little diffe...   Oct 7 2009, 07:22 PM
r_towle   The best way to do it is to remove everything. Acc...   Oct 7 2009, 07:30 PM
neil30076   Ken, check out http://www.rescue912.com/spider/Web...   Oct 7 2009, 07:46 PM
kenshapiro2002   Thanks. Ken, check out http://www.rescue912.com/...   Oct 7 2009, 08:06 PM
kenshapiro2002   Thanks guys. Some questions: 1.) The one part I m...   Oct 7 2009, 08:06 PM
neil30076   "Note which way round (freakin' Brits) t...   Oct 7 2009, 08:16 PM
SGB   1. no big deal. it will be apparent 2. use the n...   Oct 8 2009, 07:45 AM
kenshapiro2002   Thanks. When you talk about the tabs breaking, are...   Oct 8 2009, 07:51 AM
kenshapiro2002   RE: Newbie Tears Into Webers   Oct 7 2009, 08:39 PM
kenshapiro2002   RE: Newbie Tears Into Webers   Oct 7 2009, 08:40 PM
kenshapiro2002   RE: Newbie Tears Into Webers   Oct 7 2009, 08:42 PM
kenshapiro2002   First two shots were before I sprayed the outsides...   Oct 7 2009, 08:42 PM
Vacca Rabite   Mmmmmmm goooey. Keep track of all the hardware an...   Oct 8 2009, 07:20 AM
kenshapiro2002   Thanks. Know any of the answers to post #11 above?...   Oct 8 2009, 07:25 AM
SGB   The tabs that hold the float pivot inside break ea...   Oct 8 2009, 10:40 AM
kenshapiro2002   So...how come the Weber rebuild kits come with fou...   Oct 8 2009, 11:07 AM
neil30076   So...how come the Weber rebuild kits come with fo...   Oct 8 2009, 11:25 AM
kenshapiro2002   Neil, What "thick phenolic spacer"? Whe...   Oct 8 2009, 12:22 PM
neil30076   Neil, What "thick phenolic spacer"? Wh...   Oct 8 2009, 12:56 PM
SGB   [quote name='kenshapiro2002' post='1223481' date=...   Oct 8 2009, 01:45 PM
kenshapiro2002   Yeah...but I was asking about the gaskets that com...   Oct 8 2009, 02:49 PM
kenshapiro2002   I'm clueless on what you're referring to a...   Oct 8 2009, 02:51 PM
jmill   2.) How come the rebuild kit comes with a new need...   Oct 8 2009, 01:26 PM
kenshapiro2002   Gotcha. Just wondering why they have it in the reb...   Oct 8 2009, 01:30 PM
kenshapiro2002   Hmmmmmm...aircooled.com says to use the thicker ph...   Oct 8 2009, 02:58 PM
neil30076   Hmmmmmm...aircooled.com says to use the thicker p...   Oct 8 2009, 03:13 PM
tat2dphreak   use the same damn ones... thick :) if not you wi...   Oct 8 2009, 03:58 PM
r_towle   Show a pic of the gaskets. Weber rebuild kits are ...   Oct 8 2009, 05:16 PM
kenshapiro2002   Called Weber Direct and the guy said they throw in...   Oct 8 2009, 05:49 PM
kenshapiro2002   The cleaner is supposed to be kept off skin, but n...   Oct 8 2009, 05:47 PM
r_towle   The cleaner is supposed to be kept off skin, but ...   Oct 8 2009, 05:50 PM
kenshapiro2002   I believe you once said to check the floats in gas...   Oct 8 2009, 07:35 PM
Max914   The cleaner is supposed to be kept off skin, but ...   Oct 11 2009, 06:09 PM
SGB   You just don't want to get water into a leaky ...   Oct 8 2009, 08:14 PM
kenshapiro2002   That's the tab I thought you meant...the end t...   Oct 8 2009, 08:18 PM
r_towle   I use gas, and yes....if you see bubbles, replace ...   Oct 8 2009, 08:26 PM
kenshapiro2002   So...what's the reason for using gas?   Oct 8 2009, 08:44 PM
r_towle   Dunno, just seems logical Rich   Oct 8 2009, 08:51 PM
kenshapiro2002   Well, I tested my floats in water. No fumes, no ne...   Oct 12 2009, 10:41 AM
SGB   :beer2:   Oct 8 2009, 10:44 PM
r_towle   So, how is it going? get lost yet? Rich   Oct 9 2009, 05:02 PM
neil30076   So, how is it going? get lost yet? Rich Yes, en...   Oct 9 2009, 06:15 PM
SGB   I'm checking back too...   Oct 9 2009, 07:01 PM
tat2dphreak   he blew up the garage testing the float in gas, di...   Oct 9 2009, 08:22 PM
kenshapiro2002   Wasn't in a big rush because the gaskets for t...   Oct 9 2009, 11:00 PM
Gint   Believe me...I'll be posting every move. I do...   Oct 10 2009, 08:51 AM
kenshapiro2002   I've been told that my linkage is a good one, ...   Oct 10 2009, 09:11 AM
kenshapiro2002   P.S. My best guess is that the carbs will not solv...   Oct 9 2009, 11:00 PM
rhodyguy   if the intake manifolds are still off of the engin...   Oct 10 2009, 09:30 AM
kenshapiro2002   Good idea...thanks. Just checked and it's stra...   Oct 10 2009, 09:54 AM
rhodyguy   you need to figure out a better venting system. th...   Oct 10 2009, 10:41 AM
kenshapiro2002   Gotcha...glad you noticed. Will something like the...   Oct 10 2009, 11:19 AM
Gint   I'll leave the venting question to the environ...   Oct 10 2009, 11:42 AM
kenshapiro2002   I have no heating system, but do want to keep the ...   Oct 10 2009, 12:00 PM
kenshapiro2002   Are the valve covers on these guys vented?   Oct 10 2009, 12:27 PM
Gint   No. The 2.0 have head vents, the 1.8's do not...   Oct 10 2009, 01:04 PM
kenshapiro2002   4 bolt intake manifolds...a punched out 1.7 (1911c...   Oct 10 2009, 06:34 PM
type47   The 2.0 have head vents, the 1.8's do not. ...   Oct 11 2009, 12:49 PM
Gint   [quote name='Gint' post='1224282' date='Oct 10 200...   Oct 11 2009, 04:03 PM
kenshapiro2002   Hey...who hijacked my "Newbie Rebuilding Webe...   Oct 11 2009, 04:59 PM
Gint   You'll get used to it.   Oct 11 2009, 05:01 PM
kenshapiro2002   Already am! :D You'll get used to it.   Oct 11 2009, 05:28 PM
kenshapiro2002   8:24 EST...out to the garage to start putting the ...   Oct 12 2009, 07:16 AM
kenshapiro2002   What pyrose do "starter valves" have (ch...   Oct 12 2009, 08:23 AM
kenshapiro2002   pyrose = purpose What pyrose do "starter v...   Oct 12 2009, 08:23 AM
type47   Is "starter valve" a Weber thing? You...   Oct 12 2009, 08:44 AM
kenshapiro2002   Yes...a Weber thing. 99% sure it's soe kinda c...   Oct 12 2009, 08:57 AM
rhodyguy   a couple of pumps on the throttle, start it up and...   Oct 12 2009, 09:27 AM
kenshapiro2002   I just tried it and it didn't work. Oh yeah......   Oct 12 2009, 10:35 AM
jaxdream   He maybe referring to the accelartor pumps on the ...   Oct 12 2009, 09:54 AM
kenshapiro2002   Nah...and there's no "he"...it's...   Oct 12 2009, 10:37 AM
kenshapiro2002   My float was at 8mm (with gasket on), instead of t...   Oct 12 2009, 11:00 AM
r_towle   My float was at 8mm (with gasket on), instead of ...   Oct 12 2009, 11:37 AM
kenshapiro2002   And my "drop" measurement (I understand ...   Oct 12 2009, 11:11 AM
kenshapiro2002   Now...if it runs as well as it looks... Any logi...   Oct 12 2009, 12:46 PM
SirAndy   Any logic in putting the rebuilt carb back in with...   Oct 12 2009, 12:50 PM
kenshapiro2002   OK...thanks. Any logic in putting the rebuilt c...   Oct 12 2009, 01:01 PM
r_towle   Just do the other one...then you will KNOW its don...   Oct 12 2009, 01:09 PM
McMark   I'm a little late to this thread, but my comme...   Oct 12 2009, 01:31 PM
r_towle   I'm a little late to this thread, but my comm...   Oct 12 2009, 03:04 PM
kenshapiro2002   Neither do I, but then again, he didn't say th...   Oct 12 2009, 04:34 PM
kenshapiro2002   Idle - 50 Main - 115 AC Jet - 200 Emulsion Tubes ...   Oct 12 2009, 01:44 PM
jmill   I thought you went to 125 mains. Are you going ba...   Oct 12 2009, 05:17 PM
kenshapiro2002   I bought the 125s, ran them for a few days and the...   Oct 12 2009, 07:16 PM
neil30076   Whattaya mean by vent size? :blink: ( ven...   Oct 12 2009, 07:33 PM
kenshapiro2002   Oh...the auxiliary venturis! They are 28s. Hey...   Oct 12 2009, 09:02 PM
Vacca Rabite   Oh...the auxiliary venturis! They are 28s. He...   Oct 12 2009, 10:51 PM
URY914   When reinstalling the carb to the manifold, and th...   Oct 12 2009, 07:37 PM
kenshapiro2002   I had tons of popping and backfiring. I'm usin...   Oct 12 2009, 09:05 PM
jmill   Washers find a way to drop into the intake and cau...   Oct 12 2009, 09:12 PM
McMark   :rotfl: You guys are funny. :lol4:   Oct 12 2009, 09:34 PM
kenshapiro2002   See...if I just say "Thanks" (to your co...   Oct 13 2009, 05:29 AM
jaxdream   The fella is trying do solve some issues himself, ...   Oct 13 2009, 12:30 AM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 9th June 2026 - 05:04 AM
