> Best method of break in for motor rebuild?, Also what oil to use during & after
JRust
post Oct 13 2009, 08:45 PM
I am getting my rebuilt 2.0 motor back for my 74 LE resto. What is the best way to break in the motor from the time I put oil in the first time. Also what oil do you recommend for the initial break in. I plan to use Brad Penn 20w50 after. I know they make a break in oil at like 30 weight. Just curious what you guys recommend (IMG:style_emoticons/default/confused24.gif)
Also would it be better to start out with Carbs. I don't know the condition of my FI. I will be replacing all the lines & cleaning my Fuel injectors. Just seems like I could troubleshoot the carbs initially a little easier. Again what do you guys prefer?
Jake Raby
post Oct 14 2009, 07:43 AM
Engine Surgeon
Air won't push oil very well, basically not at all. The oil filter being filled with oil does no good at all if the air thats present between the pump and filter is tasked with pushing the oil through the filter.
Leaving the filter empty allows the oil to push the air from the filter and through the rest of the engine progressively filling each cavity of the oil system as it goes.
People who think they are smart by filling the oil filter couldn't be more wrong in their assumption.
JRust   Best method of break in for motor rebuild?   Oct 13 2009, 08:45 PM
underthetire   I am getting my rebuilt 2.0 motor back for my 74 ...   Oct 13 2009, 09:37 PM
Jake Raby   do not fill the filter first!! Doing so ta...   Oct 13 2009, 09:40 PM
McMark   :agree: don't fill the filter. I like break i...   Oct 13 2009, 10:10 PM
plays with cars   Curious about comments not to fill the filter: it ...   Oct 14 2009, 12:47 AM
jcd914   Curious about comments not to fill the filter: it...   Oct 14 2009, 01:01 AM
McMark   Jim's got it spot on. It's easier for the...   Oct 14 2009, 01:07 AM
Jake Raby   Air won't push oil very well, basically not at...   Oct 14 2009, 07:43 AM
Gint   Wouldn't performing a break in with carbs incr...   Oct 14 2009, 08:13 AM
charliew   A simple pressure primer made out of 3.0 inch pvc ...   Oct 14 2009, 09:23 AM
7275914911   I to am very interested in this topic. In the next...   Oct 14 2009, 10:05 AM
McMark   I'm realize we may all be talking about differ...   Oct 14 2009, 11:10 AM
9146986   I always disable the ignition after an oil change ...   Oct 14 2009, 01:30 PM
zymurgist   I always disable the ignition after an oil change...   Oct 14 2009, 03:23 PM
ConeDodger   I don't trust 30+ year old EFI for break-in be...   Oct 14 2009, 01:42 PM
tat2dphreak   does Jake have his technique laid out somewhere?   Oct 14 2009, 02:21 PM
ConeDodger   does Jake have his technique laid out somewhere?...   Oct 14 2009, 02:45 PM
Jake Raby   does Jake have his technique laid out somewhere?...   Oct 14 2009, 04:04 PM
tat2dphreak   thanks Jake, I'll have to sign up to another s...   Oct 14 2009, 04:36 PM
yeahmag   Hijack: What about filling the filter with oil whe...   Oct 14 2009, 06:09 PM
ConeDodger   Hijack: What about filling the filter with oil wh...   Oct 14 2009, 06:13 PM
McMark   :agree: I never fill a filter. Disabling the igni...   Oct 14 2009, 06:19 PM
yeahmag   Damn. Just when I thought I knew everything...   Oct 14 2009, 06:21 PM
JRust   I called the kinda local Brad Penn distributor. He...   Oct 17 2009, 01:31 PM
McMark   BP 30 wt break in oil. It's nether of the one...   Oct 17 2009, 07:59 PM
tat2dphreak   was his question tho... the "after break-in...   Oct 17 2009, 08:27 PM
JRust   was his question tho... the "after break-in...   Oct 17 2009, 09:14 PM
McMark   Come on, I can't be expected to read EVERY wor...   Oct 17 2009, 11:18 PM
JRust   That seems to be what I hear used the most. I figu...   Oct 17 2009, 11:38 PM
- Lo-Fi Version Time is now: 9th January 2026 - 08:00 AM
