| JRust |
Oct 13 2009, 08:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
I am getting my rebuilt 2.0 motor back for my 74 LE resto. What is the best way to break in the motor from the time I put oil in the first time. Also what oil do you recommend for the initial break in. I plan to use Brad Penn 20w50 after. I know they make a break in oil at like 30 weight. Just curious what you guys recommend (IMG:style_emoticons/default/confused24.gif)
Also would it be better to start out with Carbs. I don't know the condition of my FI. I will be replacing all the lines & cleaning my Fuel injectors. Just seems like I could troubleshoot the carbs initially a little easier. Again what do you guys prefer? |
| 7275914911 |
Oct 14 2009, 10:05 AM
Hummmm!!! ![]() ![]() ![]() Group: Members Posts: 757 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States
I to am very interested in this topic. In the next couple of weeks I will be ready to turn the key on my recent 2.0 2056 build.
I have BP Break In oil (30 weight), but how long should it stay in. What should I do from the first crank till I get rid of the breakin oil running wise? How do you know that the engine is primed and ready to crank? I have BP 20/50 for my regular oil after breakin. After initial breakin should I drive it like i stole it? All thoughts and input on this topic are appreciated. Hope I'm not Hijacking but my ?'s looked like they belonged here and not in a new topic. Sorry for the newbie line of questioning also.. KP |
JRust Best method of break in for motor rebuild? Oct 13 2009, 08:45 PM
underthetire
I am getting my rebuilt 2.0 motor back for my 74 ... Oct 13 2009, 09:37 PM
Jake Raby do not fill the filter first!! Doing so ta... Oct 13 2009, 09:40 PM
McMark :agree: don't fill the filter.
I like break i... Oct 13 2009, 10:10 PM
plays with cars Curious about comments not to fill the filter: it ... Oct 14 2009, 12:47 AM
jcd914
Curious about comments not to fill the filter: it... Oct 14 2009, 01:01 AM
McMark Jim's got it spot on.
It's easier for the... Oct 14 2009, 01:07 AM
Jake Raby Air won't push oil very well, basically not at... Oct 14 2009, 07:43 AM
Gint Wouldn't performing a break in with carbs incr... Oct 14 2009, 08:13 AM
charliew A simple pressure primer made out of 3.0 inch pvc ... Oct 14 2009, 09:23 AM
McMark I'm realize we may all be talking about differ... Oct 14 2009, 11:10 AM
9146986 I always disable the ignition after an oil change ... Oct 14 2009, 01:30 PM
zymurgist
I always disable the ignition after an oil change... Oct 14 2009, 03:23 PM
ConeDodger I don't trust 30+ year old EFI for break-in be... Oct 14 2009, 01:42 PM
tat2dphreak
does Jake have his technique laid out somewhere? Oct 14 2009, 02:21 PM
ConeDodger
does Jake have his technique laid out somewhere?... Oct 14 2009, 02:45 PM
Jake Raby
does Jake have his technique laid out somewhere?... Oct 14 2009, 04:04 PM
tat2dphreak thanks Jake, I'll have to sign up to another s... Oct 14 2009, 04:36 PM
yeahmag Hijack: What about filling the filter with oil whe... Oct 14 2009, 06:09 PM
ConeDodger
Hijack: What about filling the filter with oil wh... Oct 14 2009, 06:13 PM
McMark :agree: I never fill a filter. Disabling the igni... Oct 14 2009, 06:19 PM
yeahmag Damn. Just when I thought I knew everything... Oct 14 2009, 06:21 PM
JRust I called the kinda local Brad Penn distributor. He... Oct 17 2009, 01:31 PM
McMark BP 30 wt break in oil. It's nether of the one... Oct 17 2009, 07:59 PM
tat2dphreak
was his question tho... the "after break-in... Oct 17 2009, 08:27 PM
JRust
was his question tho... the "after break-in... Oct 17 2009, 09:14 PM
McMark Come on, I can't be expected to read EVERY wor... Oct 17 2009, 11:18 PM
JRust That seems to be what I hear used the most. I figu... Oct 17 2009, 11:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th January 2026 - 07:57 AM |
