> Where there's smoke...
flipb
post Oct 21 2009, 04:01 PM
Why, oh, why, can't anything be simple??
I've been planning to pull off my instument panel to fix my odometer and replace the bulbs for night-time IP lighting.
The bulbs came today from PP and I ran out, eager to do something relatively simple. Unscrewed the IP and tilted it out. I admit, I was intimidated by the number of wires and decided to see if I could replace the IP lights (at least on the Tach) with everything still hanging out of the dash. There's one bulb near the top of the tach that was easy to pull. I took the bulb out of the socket and replaced it with a new one.
Turned the ignition to On, tried the lights, and the new bulb didn't light. Figured I didn't have it seated correctly in the holder, fidgeted and tried again. No light. I put the old bulb back into the holder and tried the lights...
Low hissing sound and LOTS of smoke from behind the IP. I'm guessing that by pulling on the IP, I shorted some wire back there? Can't tell the exact source of the smoke.
I don't have a lot of experience with electrical. What's my next move?
KaptKaos
post Oct 21 2009, 04:56 PM
Family
Might be easier if you remove the steering wheel, no?
flipb   Where there's smoke...   Oct 21 2009, 04:01 PM
Vacca Rabite   Pull out everything that is in the way of you gett...   Oct 21 2009, 04:12 PM
flipb   Culprit was a green/white wire that goes into the ...   Oct 21 2009, 04:23 PM
flipb   And for the several times I've probably forgot...   Oct 21 2009, 04:27 PM
Gint   And for the several times I've probably forgot...   Oct 22 2009, 08:51 AM
jmill   You have to understand one thing. No matter what y...   Oct 21 2009, 04:52 PM
flipb   I like illustrating things. Here's the culpri...   Oct 21 2009, 04:52 PM
KaptKaos   Might be easier if you remove the steering wheel, ...   Oct 21 2009, 04:56 PM
flipb   Might be easier if you remove the steering wheel,...   Oct 21 2009, 05:20 PM
Spoke   First thing to do when noodling around behind the ...   Oct 21 2009, 05:02 PM
agentblr   I think the green and white wire is the high beam ...   Oct 21 2009, 05:21 PM
flipb   I think the green and white wire is the high beam...   Oct 21 2009, 05:25 PM
Vacca Rabite   Interesting. There are two green & white wi...   Oct 22 2009, 08:46 AM
kenshapiro2002   Shocked...even I solder (then shrink wrap) and I...   Oct 22 2009, 08:29 PM
flipb   Shocked...even I solder (then shrink wrap) and I...   Oct 22 2009, 08:55 PM
kenshapiro2002   Well...I was a Rookie three weeks ago. Now I'm...   Oct 22 2009, 09:04 PM
ahdoman   KaptKaos is right - take off the steering wheel an...   Oct 22 2009, 02:09 PM
flipb   FWIW, I'm not using LEDs. Just replacing the I...   Oct 22 2009, 07:15 PM
SLITS   It's white w/ green trace. On a '74 it go...   Oct 22 2009, 03:29 PM
bandjoey   U Electrical Mechanics can chime in on this: Was t...   Oct 22 2009, 04:21 PM
neil30076   U Electrical Mechanics can chime in on this: Was ...   Oct 22 2009, 04:45 PM
rick 918-S   U Electrical Mechanics can chime in on this: Was...   Oct 22 2009, 05:18 PM
SLITS   [quote name='neil30076' post='1229221' date='Oct ...   Oct 22 2009, 06:36 PM
JazonJJordan   :popcorn: hhummm... U Electrical Mechanics can ch...   Oct 22 2009, 08:08 PM
bandjoey   You might Get a set of LED while you're at it....   Oct 22 2009, 07:25 PM
Mikey914   The LEDs run on 2.7 volts, so if your grounds are ...   Oct 22 2009, 07:44 PM
Mikey914   This is the same set of gages in Mikey's car, ...   Oct 22 2009, 07:55 PM
Vacca Rabite   different schools of thought. Some say that solde...   Oct 23 2009, 10:18 AM
kenshapiro2002   Yeah...I've had mechanical connections come lo...   Oct 23 2009, 10:43 AM
- Lo-Fi Version Time is now: 7th January 2026 - 07:12 PM
