| tuff914 |
Oct 23 2009, 02:06 AM
Member ![]() ![]() Group: Members Posts: 67 Joined: 6-May 08 From: Australia Member No.: 9,020 Region Association: None |
Is there a secret to the castellated nut on the back wheel, I'm using a
3 ft breaker bar and all I'm achieving is bending my sidchrome "T" socket handle. Anyone know of a trick to cracking it. Thanks in advance John |
| GeorgeRud |
Oct 23 2009, 08:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I also found that a metal pipe that's fitted over my breaker bar (Craftsman of course) lets me remove the nut. I used a 4 foot piece of pipe, and if you break the breaker bar, you can always return it for a new one.
Remember, torque is force x distance in this case, so a 100 lb. weight 4 feet from the pivot will be 400 ft lbs, so you should be able to get it to come off with enough PB Blaster (or my favorite, Kroil), heat, and bouncing on the bar! |
tuff914 Castellated Nut Oct 23 2009, 02:06 AM
cwpeden Take out the cotter pin?
Or a good solid impact g... Oct 23 2009, 02:58 AM
zymurgist PB Blaster (or your equivalent penetrating oil) an... Oct 23 2009, 06:37 AM
SLITS 1/2" breaker bar, socket and about a 3' s... Oct 23 2009, 08:08 AM
tradisrad That bolt is torqued to 250 lbs. It can be tough t... Oct 23 2009, 08:34 AM
Gigamight Sorry to hijack, but I was going to start a simila... Oct 23 2009, 10:12 AM
aircooledtechguy This is the tool I used to remove these from a par... Oct 23 2009, 10:47 AM
brp986s If you're hopping on your cheater and your bre... Oct 23 2009, 10:52 AM
Vacca Rabite
If you're hopping on your cheater and your br... Oct 23 2009, 04:03 PM
Cap'n Krusty I use a 4 ft long piece of 2 inch angle iron, dril... Oct 23 2009, 11:29 AM
GeorgeRud I forgot to include in my post that you do need to... Oct 23 2009, 12:26 PM
Elliot Cannon Use a 3/4 inch breaker bar, a 4 foot extension pip... Oct 23 2009, 01:32 PM
DBCooper If you've done all of the above and that pig s... Oct 23 2009, 01:42 PM
jhadler
Keep this in mind when you're bouncing up and... Oct 23 2009, 03:32 PM
6freak BIG BALLS :lol4: IF YOU DONT HAVE THEM TAKE YOUR N... Oct 23 2009, 01:42 PM
jhadler Except for the part that actually broke under load... Oct 23 2009, 06:09 PM
Jeffs9146 I went to a tool rental place and rented a 3/4 imp... Oct 23 2009, 06:44 PM
DBCooper Now THAT'S what works!!! More hor... Oct 23 2009, 09:18 PM
type2man
Problem solved.....36mm welded onto an iron ... Oct 24 2009, 05:51 PM
Cap'n Krusty That's fine for a 356 or an old VW bug, but mo... Oct 24 2009, 06:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th September 2026 - 02:19 AM |
