> Castellated Nut, How do you loosen the sucker
tuff914
post Oct 23 2009, 02:06 AM
Is there a secret to the castellated nut on the back wheel, I'm using a
3 ft breaker bar and all I'm achieving is bending my sidchrome "T" socket
handle.
Anyone know of a trick to cracking it.
Thanks in advance
John
Cap'n Krusty
post Oct 23 2009, 11:29 AM
Cap'n Krusty
I use a 4 ft long piece of 2 inch angle iron, drilled for 2 lug bolts. Propped against the ground, it provides plenty of counter force for the socket, breaker bar, and "extension" (cheater). My bar is drilled for numerous applications, such as flywheels, 4 and 5 lug drums/rotors, front pulleys, and such. The Cap'n
tuff914   Castellated Nut   Oct 23 2009, 02:06 AM
cwpeden   Take out the cotter pin? Or a good solid impact g...   Oct 23 2009, 02:58 AM
zymurgist   PB Blaster (or your equivalent penetrating oil) an...   Oct 23 2009, 06:37 AM
SLITS   1/2" breaker bar, socket and about a 3' s...   Oct 23 2009, 08:08 AM
tradisrad   That bolt is torqued to 250 lbs. It can be tough t...   Oct 23 2009, 08:34 AM
GeorgeRud   I also found that a metal pipe that's fitted o...   Oct 23 2009, 08:41 AM
Gigamight   Sorry to hijack, but I was going to start a simila...   Oct 23 2009, 10:12 AM
aircooledtechguy   This is the tool I used to remove these from a par...   Oct 23 2009, 10:47 AM
brp986s   If you're hopping on your cheater and your bre...   Oct 23 2009, 10:52 AM
Vacca Rabite   If you're hopping on your cheater and your br...   Oct 23 2009, 04:03 PM
Cap'n Krusty   I use a 4 ft long piece of 2 inch angle iron, dril...   Oct 23 2009, 11:29 AM
GeorgeRud   I forgot to include in my post that you do need to...   Oct 23 2009, 12:26 PM
Elliot Cannon   Use a 3/4 inch breaker bar, a 4 foot extension pip...   Oct 23 2009, 01:32 PM
DBCooper   If you've done all of the above and that pig s...   Oct 23 2009, 01:42 PM
jhadler   Keep this in mind when you're bouncing up and...   Oct 23 2009, 03:32 PM
6freak   BIG BALLS :lol4: IF YOU DONT HAVE THEM TAKE YOUR N...   Oct 23 2009, 01:42 PM
jhadler   Except for the part that actually broke under load...   Oct 23 2009, 06:09 PM
Jeffs9146   I went to a tool rental place and rented a 3/4 imp...   Oct 23 2009, 06:44 PM
DBCooper   Now THAT'S what works!!! More hor...   Oct 23 2009, 09:18 PM
type2man   Problem solved.....36mm welded onto an iron ...   Oct 24 2009, 05:51 PM
Cap'n Krusty   That's fine for a 356 or an old VW bug, but mo...   Oct 24 2009, 06:16 PM
- Lo-Fi Version Time is now: 18th September 2026 - 02:18 AM
