> Castellated Nut, How do you loosen the sucker
tuff914
post Oct 23 2009, 02:06 AM
Is there a secret to the castellated nut on the back wheel, I'm using a
3 ft breaker bar and all I'm achieving is bending my sidchrome "T" socket
handle.
Anyone know of a trick to cracking it.
Thanks in advance
John
DBCooper
post Oct 23 2009, 01:42 PM
14's in the 13's with ATTITUDE
If you've done all of the above and that pig still hasn't budged then kneel and pray.
If that doesn't work then throw it in the truck and take it to any local truck repair shop (look it up). Have them take their 3/4" impact gun to it. It will take them no more than 5 seconds and won't even look like it was stuck. (IMG:style_emoticons/default/biggrin.gif)
Keep this in mind when you're bouncing up and down on that 4 foot cheater on your breaker bar and wondering just when the whole thing's going to snap and where and how hard that's going to dump you. (IMG:style_emoticons/default/blink.gif)
tuff914   Castellated Nut   Oct 23 2009, 02:06 AM
cwpeden   Take out the cotter pin? Or a good solid impact g...   Oct 23 2009, 02:58 AM
zymurgist   PB Blaster (or your equivalent penetrating oil) an...   Oct 23 2009, 06:37 AM
SLITS   1/2" breaker bar, socket and about a 3' s...   Oct 23 2009, 08:08 AM
tradisrad   That bolt is torqued to 250 lbs. It can be tough t...   Oct 23 2009, 08:34 AM
GeorgeRud   I also found that a metal pipe that's fitted o...   Oct 23 2009, 08:41 AM
Gigamight   Sorry to hijack, but I was going to start a simila...   Oct 23 2009, 10:12 AM
aircooledtechguy   This is the tool I used to remove these from a par...   Oct 23 2009, 10:47 AM
brp986s   If you're hopping on your cheater and your bre...   Oct 23 2009, 10:52 AM
Vacca Rabite   If you're hopping on your cheater and your br...   Oct 23 2009, 04:03 PM
Cap'n Krusty   I use a 4 ft long piece of 2 inch angle iron, dril...   Oct 23 2009, 11:29 AM
GeorgeRud   I forgot to include in my post that you do need to...   Oct 23 2009, 12:26 PM
Elliot Cannon   Use a 3/4 inch breaker bar, a 4 foot extension pip...   Oct 23 2009, 01:32 PM
DBCooper   If you've done all of the above and that pig s...   Oct 23 2009, 01:42 PM
jhadler   Keep this in mind when you're bouncing up and...   Oct 23 2009, 03:32 PM
6freak   BIG BALLS :lol4: IF YOU DONT HAVE THEM TAKE YOUR N...   Oct 23 2009, 01:42 PM
jhadler   Except for the part that actually broke under load...   Oct 23 2009, 06:09 PM
Jeffs9146   I went to a tool rental place and rented a 3/4 imp...   Oct 23 2009, 06:44 PM
DBCooper   Now THAT'S what works!!! More hor...   Oct 23 2009, 09:18 PM
type2man   Problem solved.....36mm welded onto an iron ...   Oct 24 2009, 05:51 PM
Cap'n Krusty   That's fine for a 356 or an old VW bug, but mo...   Oct 24 2009, 06:16 PM
- Lo-Fi Version Time is now: 18th September 2026 - 02:19 AM
