> Castellated Nut, How do you loosen the sucker
tuff914
post Oct 23 2009, 02:06 AM
Is there a secret to the castellated nut on the back wheel, I'm using a
3 ft breaker bar and all I'm achieving is bending my sidchrome "T" socket
handle.
Anyone know of a trick to cracking it.
Thanks in advance
John
brp986s
post Oct 23 2009, 10:52 AM
If you're hopping on your cheater and your breaker snaps get ready to do some fancy footwork. I didn't want to risk it so I got craftsman 3/4 " breaker and sockets. However, the weak point of the 3/4" breaker is no stronger than the 1/2" breaker. Thanks for nothing. Seems craftsman is going harbor freight on us.
VaccaRabite
post Oct 23 2009, 04:03 PM
En Garde!
QUOTE(brp986s @ Oct 23 2009, 11:52 AM) *
I love that feeling. You see it happen. Time slows to the point where you are sure you have enough to take corrective action. The tool snaps, part breaks, etc, and from that point you are your own passenger as you stumble backwards through the garage, eventually tripping over something and going ass over teacups. Its the extreme apparent slowness that is so interesting. It may be all over in a second, but at the time it seems to go on an on.
Zach
tuff914   Castellated Nut   Oct 23 2009, 02:06 AM
cwpeden   Take out the cotter pin? Or a good solid impact g...   Oct 23 2009, 02:58 AM
zymurgist   PB Blaster (or your equivalent penetrating oil) an...   Oct 23 2009, 06:37 AM
SLITS   1/2" breaker bar, socket and about a 3' s...   Oct 23 2009, 08:08 AM
tradisrad   That bolt is torqued to 250 lbs. It can be tough t...   Oct 23 2009, 08:34 AM
GeorgeRud   I also found that a metal pipe that's fitted o...   Oct 23 2009, 08:41 AM
Gigamight   Sorry to hijack, but I was going to start a simila...   Oct 23 2009, 10:12 AM
aircooledtechguy   This is the tool I used to remove these from a par...   Oct 23 2009, 10:47 AM
brp986s   If you're hopping on your cheater and your bre...   Oct 23 2009, 10:52 AM
Vacca Rabite   If you're hopping on your cheater and your br...   Oct 23 2009, 04:03 PM
Cap'n Krusty   I use a 4 ft long piece of 2 inch angle iron, dril...   Oct 23 2009, 11:29 AM
GeorgeRud   I forgot to include in my post that you do need to...   Oct 23 2009, 12:26 PM
Elliot Cannon   Use a 3/4 inch breaker bar, a 4 foot extension pip...   Oct 23 2009, 01:32 PM
DBCooper   If you've done all of the above and that pig s...   Oct 23 2009, 01:42 PM
jhadler   Keep this in mind when you're bouncing up and...   Oct 23 2009, 03:32 PM
6freak   BIG BALLS :lol4: IF YOU DONT HAVE THEM TAKE YOUR N...   Oct 23 2009, 01:42 PM
jhadler   Except for the part that actually broke under load...   Oct 23 2009, 06:09 PM
Jeffs9146   I went to a tool rental place and rented a 3/4 imp...   Oct 23 2009, 06:44 PM
DBCooper   Now THAT'S what works!!! More hor...   Oct 23 2009, 09:18 PM
type2man   Problem solved.....36mm welded onto an iron ...   Oct 24 2009, 05:51 PM
Cap'n Krusty   That's fine for a 356 or an old VW bug, but mo...   Oct 24 2009, 06:16 PM
- Lo-Fi Version Time is now: 18th September 2026 - 02:19 AM
