| tuff914 |
Oct 23 2009, 02:06 AM
Member ![]() ![]() Group: Members Posts: 67 Joined: 6-May 08 From: Australia Member No.: 9,020 Region Association: None |
Is there a secret to the castellated nut on the back wheel, I'm using a
3 ft breaker bar and all I'm achieving is bending my sidchrome "T" socket handle. Anyone know of a trick to cracking it. Thanks in advance John |
| jhadler |
Oct 23 2009, 06:09 PM
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Except for the part that actually broke under load. It will tend to depart the scene of the crime at a great velocity. Hopefully it simply overtakes you and it imbeds itself in the wall before you reach it. Otherwise, it might imbed itself in you...
-Josh2 |
tuff914 Castellated Nut Oct 23 2009, 02:06 AM
cwpeden Take out the cotter pin?
Or a good solid impact g... Oct 23 2009, 02:58 AM
zymurgist PB Blaster (or your equivalent penetrating oil) an... Oct 23 2009, 06:37 AM
SLITS 1/2" breaker bar, socket and about a 3' s... Oct 23 2009, 08:08 AM
tradisrad That bolt is torqued to 250 lbs. It can be tough t... Oct 23 2009, 08:34 AM
GeorgeRud I also found that a metal pipe that's fitted o... Oct 23 2009, 08:41 AM
Gigamight Sorry to hijack, but I was going to start a simila... Oct 23 2009, 10:12 AM
aircooledtechguy This is the tool I used to remove these from a par... Oct 23 2009, 10:47 AM
brp986s If you're hopping on your cheater and your bre... Oct 23 2009, 10:52 AM
Vacca Rabite
If you're hopping on your cheater and your br... Oct 23 2009, 04:03 PM
Cap'n Krusty I use a 4 ft long piece of 2 inch angle iron, dril... Oct 23 2009, 11:29 AM
GeorgeRud I forgot to include in my post that you do need to... Oct 23 2009, 12:26 PM
Elliot Cannon Use a 3/4 inch breaker bar, a 4 foot extension pip... Oct 23 2009, 01:32 PM
DBCooper If you've done all of the above and that pig s... Oct 23 2009, 01:42 PM
jhadler
Keep this in mind when you're bouncing up and... Oct 23 2009, 03:32 PM
6freak BIG BALLS :lol4: IF YOU DONT HAVE THEM TAKE YOUR N... Oct 23 2009, 01:42 PM
Jeffs9146 I went to a tool rental place and rented a 3/4 imp... Oct 23 2009, 06:44 PM
DBCooper Now THAT'S what works!!! More hor... Oct 23 2009, 09:18 PM
type2man
Problem solved.....36mm welded onto an iron ... Oct 24 2009, 05:51 PM
Cap'n Krusty That's fine for a 356 or an old VW bug, but mo... Oct 24 2009, 06:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th September 2026 - 02:19 AM |
