| rfuerst911sc |
Oct 27 2009, 05:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
As I'm nearing the point of turning the key after 3 years of work I thought I would share what I did for a front oil cooler. First off it's a 75 chassis that has a 911 3.0 installed. Living in Florida I knew a oil cooler was a must. After looking at what was done in the past by others I decided to go a different route. My criteria was I wanted to be able to use the front trunk as a trunk. This will be a street,AX and DE machine. So based on that I went about laying this out in my head. Once I had a basic plan I started buying parts. First off was a MB oil cooler from a diesel. It's made by Behr and well built. I then came up with my mount which basically is two 1/4-20 by 6 inch long bolts welded to the tub facing forward. The cooler has two hoops that slide over the bolts. I made some stand offs to keep the cooler spaced away from the tub for good air flow. I used -12AN hose to go from the cooler to the rear mounted Mocal thermostat. I wanted to keep the length of the hoses to a minimum so I ran them straight back. Under the tub just off center are two channels in the tub. I glued tie down plates to the tub and zip tied the lines tight to the floor. In the rear is the normal routing to engine,thermostat and oil tank. Yes I know my setup is more vunerable to a front end crash or doing something stupid but 911's have had front mounted coolers for a long time mounted up front and low so it can be done. I will be making some stand off blocks in the trunk just high enough to have a front mounted full size spare and then the carpeted cover. Will barely be noticeable to the common eye. I know this isn't for everyone but I'd thought I'd share now that I have everything installed. I am now fabricating a stock valance to have a cutout/snout around the cooler similiar to a early 911 RS valance. Hopefully the pics will show it off. (IMG:style_emoticons/default/biggrin.gif)
| J P Stein |
Oct 28 2009, 01:20 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
While I admire "thinking outside the box", I can see no reason to mount
a cooler & lines in harms way when good protection is easily available. |
rfuerst911sc my front mounted oil cooler, a little different Oct 27 2009, 05:31 PM
SLITS Not bad ... you did what I was going to do, except... Oct 27 2009, 05:37 PM
Dr. Roger what kind of debris protection is going over it?
... Oct 27 2009, 05:42 PM
rfuerst911sc
... Oct 27 2009, 06:11 PM
jhadler
what kind of debris protection is going over it?... Oct 27 2009, 06:46 PM
rfuerst911sc
[quote name='rfuerst911sc' post='1231313' date='O... Oct 27 2009, 07:05 PM
SLITS Damn, I have the mesh screen and bump bar from an ... Oct 27 2009, 06:32 PM
rfuerst911sc
Damn, I have the mesh screen and bump bar from an... Oct 27 2009, 07:08 PM
jmill I like the placement. Are you sure you want to tr... Oct 27 2009, 06:48 PM
rfuerst911sc
I like the placement. Are you sure you want to t... Oct 27 2009, 07:13 PM
ME733
I like the placement. Are you sure you want to t... Oct 29 2009, 07:22 AM
john rogers I would guess the first tech inspector that sees t... Oct 27 2009, 07:32 PM
rfuerst911sc
I would guess the first tech inspector that sees ... Oct 27 2009, 07:38 PM
jhadler It's probably better that they're flexible... Oct 28 2009, 11:55 AM
zymurgist Nice installation! You went out of your way t... Oct 28 2009, 12:26 PM
SirAndy Some of the GTs used a similar setup. I've got... Oct 28 2009, 12:56 PM
jhadler I was thinking something like a single chin bar in... Oct 28 2009, 01:10 PM
race914 'back in the day' I had the same setup.
h... Oct 28 2009, 02:42 PM
cal44 Why can't hard oil lines be plumbed through th... Oct 28 2009, 03:37 PM
iamchappy I used to have the GT spoiler on my first 914 with... Oct 28 2009, 03:54 PM
rfuerst911sc Thanks everyone for the feedback it is appreciated... Oct 28 2009, 06:10 PM
jhadler
Thanks everyone for the feedback it is appreciate... Oct 28 2009, 06:59 PM
rfuerst911sc
Thanks everyone for the feedback it is appreciat... Oct 28 2009, 07:39 PM
oldschool
Thanks everyone for the feedback it is appreciate... Oct 29 2009, 01:52 AM
jhadler Still... I love the look, and the best part is tha... Oct 28 2009, 07:10 PM
J P Stein I do some thinking also. I passed this way bout 10... Oct 28 2009, 08:22 PM
SirAndy Crappy pic, but you get the idea ... Oct 29 2009, 12:03 AM
john rogers There is a huge difference between breaking open y... Oct 29 2009, 12:43 AM
sean_v8_914 is this a track car? did I miss that statement som... Oct 29 2009, 07:47 AM
ME733 :popcorn: .....Placing your OIL LINES on the botto... Oct 29 2009, 07:53 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:56 PM |
