> my front mounted oil cooler, a little different
rfuerst911sc
post Oct 27 2009, 05:31 PM
As I'm nearing the point of turning the key after 3 years of work I thought I would share what I did for a front oil cooler. First off it's a 75 chassis that has a 911 3.0 installed. Living in Florida I knew a oil cooler was a must. After looking at what was done in the past by others I decided to go a different route. My criteria was I wanted to be able to use the front trunk as a trunk. This will be a street,AX and DE machine. So based on that I went about laying this out in my head. Once I had a basic plan I started buying parts. First off was a MB oil cooler from a diesel. It's made by Behr and well built. I then came up with my mount which basically is two 1/4-20 by 6 inch long bolts welded to the tub facing forward. The cooler has two hoops that slide over the bolts. I made some stand offs to keep the cooler spaced away from the tub for good air flow. I used -12AN hose to go from the cooler to the rear mounted Mocal thermostat. I wanted to keep the length of the hoses to a minimum so I ran them straight back. Under the tub just off center are two channels in the tub. I glued tie down plates to the tub and zip tied the lines tight to the floor. In the rear is the normal routing to engine,thermostat and oil tank. Yes I know my setup is more vunerable to a front end crash or doing something stupid but 911's have had front mounted coolers for a long time mounted up front and low so it can be done. I will be making some stand off blocks in the trunk just high enough to have a front mounted full size spare and then the carpeted cover. Will barely be noticeable to the common eye. I know this isn't for everyone but I'd thought I'd share now that I have everything installed. I am now fabricating a stock valance to have a cutout/snout around the cooler similiar to a early 911 RS valance. Hopefully the pics will show it off. (IMG:style_emoticons/default/biggrin.gif)
rfuerst911sc
post Oct 28 2009, 06:10 PM
Thanks everyone for the feedback it is appreciated. You've given me a few ideas about the clamp mounts that I may incorporate. Just a few things.
1. This is not a race car, as I stated in my original post it is street , AX and DE.
2. Yes I may incorporate a chin bar to be safe. However the bottom of the cooler is over 6 1/2 inches off the pavement. Yes I could hit a street curb but it's going to hit the suspension pieces also and I've never had that happen in any car I've driven.
3. I don't accept that just because the oil lines are exposed that they are an accident waiting to happen. The oil lines on almost every 911 since 1970 has oil lines exposed on the outside of the passenger side rocker. Yes they are hard bronze lines but they are right in line with debris flying off the front right tire.
4. As stated Porsche did install a front cooler just like I have on the 914 GT but yes they also mounted them in the trunk. So that's a push ?
5. My 911SC is set to Euro height and I have a AC belly condensor that is almost the full width of the car mounted directly under the seats. It is exactly 4 inches off the pavement. I've been running this car with this condensor at this height for aprox. 3 years and have never even scraped it on anything. That includes AX and DE.
Just saying I did my homework and for me I have a good solution based on my experiences with my 911 and other Porsches. It doesn't mean I'm right and time will tell if I am. It's all good. (IMG:style_emoticons/default/beerchug.gif)
oldschool
post Oct 29 2009, 01:52 AM
QUOTE(rfuerst911sc @ Oct 28 2009, 05:10 PM) *
Right on man (a man with experience is never at the mercy of a man with a argument)
rfuerst911sc   my front mounted oil cooler, a little different   Oct 27 2009, 05:31 PM
SLITS   Not bad ... you did what I was going to do, except...   Oct 27 2009, 05:37 PM
Dr. Roger   what kind of debris protection is going over it? ...   Oct 27 2009, 05:42 PM
rfuerst911sc   what kind of debris protection is going over it? ...   Oct 27 2009, 06:11 PM
jhadler   what kind of debris protection is going over it?...   Oct 27 2009, 06:46 PM
rfuerst911sc   [quote name='rfuerst911sc' post='1231313' date='O...   Oct 27 2009, 07:05 PM
SLITS   Damn, I have the mesh screen and bump bar from an ...   Oct 27 2009, 06:32 PM
rfuerst911sc   Damn, I have the mesh screen and bump bar from an...   Oct 27 2009, 07:08 PM
jmill   I like the placement. Are you sure you want to tr...   Oct 27 2009, 06:48 PM
rfuerst911sc   I like the placement. Are you sure you want to t...   Oct 27 2009, 07:13 PM
ME733   I like the placement. Are you sure you want to t...   Oct 29 2009, 07:22 AM
john rogers   I would guess the first tech inspector that sees t...   Oct 27 2009, 07:32 PM
rfuerst911sc   I would guess the first tech inspector that sees ...   Oct 27 2009, 07:38 PM
jhadler   It's probably better that they're flexible...   Oct 28 2009, 11:55 AM
zymurgist   Nice installation! You went out of your way t...   Oct 28 2009, 12:26 PM
SirAndy   Some of the GTs used a similar setup. I've got...   Oct 28 2009, 12:56 PM
jhadler   I was thinking something like a single chin bar in...   Oct 28 2009, 01:10 PM
J P Stein   While I admire "thinking outside the box...   Oct 28 2009, 01:20 PM
race914   'back in the day' I had the same setup. h...   Oct 28 2009, 02:42 PM
cal44   Why can't hard oil lines be plumbed through th...   Oct 28 2009, 03:37 PM
iamchappy   I used to have the GT spoiler on my first 914 with...   Oct 28 2009, 03:54 PM
rfuerst911sc   Thanks everyone for the feedback it is appreciated...   Oct 28 2009, 06:10 PM
jhadler   Thanks everyone for the feedback it is appreciate...   Oct 28 2009, 06:59 PM
rfuerst911sc   Thanks everyone for the feedback it is appreciat...   Oct 28 2009, 07:39 PM
oldschool   Thanks everyone for the feedback it is appreciate...   Oct 29 2009, 01:52 AM
jhadler   Still... I love the look, and the best part is tha...   Oct 28 2009, 07:10 PM
J P Stein   I do some thinking also. I passed this way bout 10...   Oct 28 2009, 08:22 PM
SirAndy   Crappy pic, but you get the idea ...   Oct 29 2009, 12:03 AM
john rogers   There is a huge difference between breaking open y...   Oct 29 2009, 12:43 AM
sean_v8_914   is this a track car? did I miss that statement som...   Oct 29 2009, 07:47 AM
ME733   :popcorn: .....Placing your OIL LINES on the botto...   Oct 29 2009, 07:53 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:56 PM
