| Racing916 |
Nov 16 2009, 08:00 PM
Member ![]() ![]() Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States |
hello,
I am currently upgrading my 914-6 to vented rotors. My hope was to take a Front "M" caliper and mount it on the rear using the 911 (69-83 Rear) vented rotors. I mock fitted the caliper and rotor and it looks like I need to place a small spacer between the caliper and the mount on the rear trailing arm (not a problem) The issue is the 911 rotors get larger as you get closer to the brake surface and rub on the "M" Calipers. Has anyone else had this issue? I realize they are larger for the parking brake, is there a parking brake delete option? 914-6GT vented rotors, suppliers? Thanks for any help, back to the drawing board! Steve |
| brant |
Nov 16 2009, 09:34 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I think I'm a bit outgunned JP!
at one of the races this summer they had an evening event... after many beers.... they had all of the drivers stand on a scale and fill sand bags until each hit 250# then 4 equal go karts were lined up on the 2.5ish mile track each heat of equal weight'd drivers went out side by side the winner of the heat progressed to the semi-finals and beyond... I didn't win anything but it sure was fun being dead equal to all of your competitors in weight and power... I'm thinking that I'd need to shed more than a few pounds to run with JP! hope your doing well brant |
Racing916 Help with Brake Upgrade Nov 16 2009, 08:00 PM
Jeffs9146 I think it is easier to put the spacers between th... Nov 16 2009, 08:18 PM
Van914 Steve,
That is the set up I am running on my car. ... Nov 16 2009, 08:29 PM
Racing916
Steve,
That is the set up I am running on my car.... Nov 16 2009, 08:38 PM
Eric_Shea 48mm pistons on the rear?
OK... I give up. :wack... Nov 16 2009, 08:33 PM
Racing916
OK... I give up. :wac... Nov 16 2009, 08:40 PM
Racing916 Thanks for the reply Jeff. I would think shrinkin... Nov 16 2009, 08:36 PM
Eric_Shea Use "Rear" M-Calipers with the #31 pad (... Nov 16 2009, 08:43 PM
Racing916
Use "Rear" M-Calipers with the #31 pad ... Nov 16 2009, 08:49 PM
davep What M calipers are you wanting to use on the rear... Nov 16 2009, 08:51 PM
Racing916
What M calipers are you wanting to use on the rea... Nov 16 2009, 08:57 PM
Racing916 Eric,
Sorry I read your reply fast and did not se... Nov 16 2009, 09:03 PM
Eric_Shea
No. It's not made for that application.
As... Nov 16 2009, 08:59 PM
Eric_Shea
Install rear M-Calipers and fret no more, especi... Nov 16 2009, 09:06 PM
Eric_Shea
Like "other" 911 items, we use them as... Nov 16 2009, 09:08 PM
brant I've had vented rear rotors on a 914....
absol... Nov 16 2009, 09:17 PM
Racing916
abso... Nov 16 2009, 09:37 PM
J P Stein I ran SC rears with S fronts. The stock 4 pooper r... Nov 16 2009, 09:28 PM
Eric_Shea
Agree... that said, there's only about 4.2lb... Nov 16 2009, 09:41 PM
brant
Agree... that said, there's only about 4.2l... Nov 16 2009, 09:56 PM
brant what pads?
you can buy pads to run in different te... Nov 16 2009, 09:44 PM
Racing916
what pads?
you can buy pads to run in different t... Nov 16 2009, 09:50 PM
brant no.. my front KFP's last 2times longer than m... Nov 16 2009, 09:54 PM
Racing916
no.. my front KFP's last 2times longer than ... Nov 16 2009, 10:07 PM
Van914 Racing916,
I bought my vented rotors here: http://... Nov 17 2009, 06:03 AM
914Sixer There is a correct rotor for the 914-6 racing appl... Nov 17 2009, 07:52 AM
Racing916 Brake Update Pictures of the front and rears, than... Dec 4 2009, 06:58 PM
Racing916 front Dec 4 2009, 06:59 PM
Racing916 rear Dec 4 2009, 07:00 PM
Eric_Shea :trophy: Dec 4 2009, 09:03 PM
Racing916
:trophy:
Thanks for all your input Eric! Dec 5 2009, 07:20 AM
charliew I always thought that if you need to pump the brak... Dec 5 2009, 10:34 AM
Krieger914 So is it worth it, and is it possible to get the r... Feb 23 2010, 11:11 PM
Eric_Shea
Andy, in Steve's situation... maybe. In mos... Feb 24 2010, 09:44 AM
Krieger914 So what "m" rears are they: 84-89? for ... Feb 24 2010, 09:51 AM
Eric_Shea 1969 through 1983. The 84-89 have larger pistons ... Feb 24 2010, 09:56 AM
914Sixer Rear 914-6 GT vented rotors(901.352.041.12)were st... Feb 24 2010, 07:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:31 PM |
