> Help with Brake Upgrade, Rear Vented rotors
Racing916
post Nov 16 2009, 08:00 PM
hello,
I am currently upgrading my 914-6 to vented rotors. My hope was to take a Front "M" caliper and mount it on the rear using the 911 (69-83 Rear) vented rotors. I mock fitted the caliper and rotor and it looks like I need to place a small spacer between the caliper and the mount on the rear trailing arm (not a problem) The issue is the 911 rotors get larger as you get closer to the brake surface and rub on the "M" Calipers. Has anyone else had this issue? I realize they are larger for the parking brake, is there a parking brake delete option? 914-6GT vented rotors, suppliers?
Thanks for any help, back to the drawing board!
Steve
brant
post Nov 16 2009, 09:54 PM
no.. my front KFP's last 2times longer than my rears
I can get a whole season out of a set of fronts... only 3-4 weekends from a set of rears. and our car is a double driver too.. with my dad.
what compounds (what color) are your front/rear pads
try KPF gold color on the back or go up one step from there if you need to
which calipers do you use front/rear?
Racing916
post Nov 16 2009, 10:07 PM
QUOTE(brant @ Nov 16 2009, 07:54 PM) *
I was running M caliper fronts and stock 914-4 calipers in back both with KFP gold compound and found the fronts still wear 2X as fast as the rear.
I than upgraded to Wide A calipers on the front and still had 914-4 stock on the rear. I decided to try the Hawk HP on the front because they are much cheaper and people at the track really liked them. The rears were still KFP golds, as Hawk did not make HP pads for the rear. I did notice better braking with the upgraded front calipers, but the wear remains the same with the fronts wearing 2X faster than the rears.
Racing916   Help with Brake Upgrade   Nov 16 2009, 08:00 PM
Jeffs9146   I think it is easier to put the spacers between th...   Nov 16 2009, 08:18 PM
Van914   Steve, That is the set up I am running on my car. ...   Nov 16 2009, 08:29 PM
Racing916   Steve, That is the set up I am running on my car....   Nov 16 2009, 08:38 PM
Eric_Shea   48mm pistons on the rear? OK... I give up. :wack...   Nov 16 2009, 08:33 PM
Racing916   48mm pistons on the rear? OK... I give up. :wac...   Nov 16 2009, 08:40 PM
Racing916   Thanks for the reply Jeff. I would think shrinkin...   Nov 16 2009, 08:36 PM
Eric_Shea   Use "Rear" M-Calipers with the #31 pad (...   Nov 16 2009, 08:43 PM
Racing916   Use "Rear" M-Calipers with the #31 pad ...   Nov 16 2009, 08:49 PM
davep   What M calipers are you wanting to use on the rear...   Nov 16 2009, 08:51 PM
Racing916   What M calipers are you wanting to use on the rea...   Nov 16 2009, 08:57 PM
Racing916   Eric, Sorry I read your reply fast and did not se...   Nov 16 2009, 09:03 PM
Eric_Shea   No. It's not made for that application. As...   Nov 16 2009, 08:59 PM
Eric_Shea   Install rear M-Calipers and fret no more, especi...   Nov 16 2009, 09:06 PM
Eric_Shea   Like "other" 911 items, we use them as...   Nov 16 2009, 09:08 PM
brant   I've had vented rear rotors on a 914.... absol...   Nov 16 2009, 09:17 PM
Racing916   I've had vented rear rotors on a 914.... abso...   Nov 16 2009, 09:37 PM
J P Stein   I ran SC rears with S fronts. The stock 4 pooper r...   Nov 16 2009, 09:28 PM
brant   I think I'm a bit outgunned JP! at one of...   Nov 16 2009, 09:34 PM
Eric_Shea   Agree... that said, there's only about 4.2lb...   Nov 16 2009, 09:41 PM
brant   Agree... that said, there's only about 4.2l...   Nov 16 2009, 09:56 PM
brant   what pads? you can buy pads to run in different te...   Nov 16 2009, 09:44 PM
Racing916   what pads? you can buy pads to run in different t...   Nov 16 2009, 09:50 PM
brant   no.. my front KFP's last 2times longer than m...   Nov 16 2009, 09:54 PM
Racing916   no.. my front KFP's last 2times longer than ...   Nov 16 2009, 10:07 PM
Van914   Racing916, I bought my vented rotors here: http://...   Nov 17 2009, 06:03 AM
914Sixer   There is a correct rotor for the 914-6 racing appl...   Nov 17 2009, 07:52 AM
Racing916   Brake Update Pictures of the front and rears, than...   Dec 4 2009, 06:58 PM
Racing916   front   Dec 4 2009, 06:59 PM
Racing916   rear   Dec 4 2009, 07:00 PM
Eric_Shea   :trophy:   Dec 4 2009, 09:03 PM
Racing916   :trophy: Thanks for all your input Eric!   Dec 5 2009, 07:20 AM
charliew   I always thought that if you need to pump the brak...   Dec 5 2009, 10:34 AM
Krieger914   So is it worth it, and is it possible to get the r...   Feb 23 2010, 11:11 PM
Eric_Shea   Andy, in Steve's situation... maybe. In mos...   Feb 24 2010, 09:44 AM
Krieger914   So what "m" rears are they: 84-89? for ...   Feb 24 2010, 09:51 AM
Eric_Shea   1969 through 1983. The 84-89 have larger pistons ...   Feb 24 2010, 09:56 AM
914Sixer   Rear 914-6 GT vented rotors(901.352.041.12)were st...   Feb 24 2010, 07:34 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:30 PM
