Question about the fuel line in the tunnel, what does the original look like? |
dkos |
Nov 16 2009, 02:59 PM
say, "RUST"! Group: Members Posts: 295 Joined: 1-December 04 From: Philadelphia, PA Member No.: 3,204 Region Association: None |
How can I tell if the tunnel fuel lines have already been replace? Someone messed around with something in my tunnel. There is a large opening cut in the top of the tunnel near the front of the car and the existing service opening in the rear of the tunnel has been "expanded". The firewall in the engine compartment where everything comes out of the tunnel looks messed with too...tho it's hard to tell because it's so gooped up with undercoating.
It looks and feels like the lines in the tunnel are copper coming in from the engine compartment side, but somewhere near the front of the tunnel they feel like they turn into plastic (or rubber). It feels like a very smooth transition...almost like the tubes were butted up against each other and taped! The plastic tubes feel smooth and solid and flexible...not brittle. What were the original fuel lines like? |
underthetire |
Nov 16 2009, 04:25 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Someone put brake line tube in. Most SS, and all copper is non-magnetic. Brake line is usually plated with a wierd green coating.
dkos |
Nov 16 2009, 04:34 PM
Someone put brake line tube in. Most SS, and all copper is non-magnetic. Brake line is usually plated with a wierd green coating. Interesting. Maybe I'm looking at the wrong lines in the rear of the tunnel. I've color keyed the picture of the tunnel. The pink is the fuel line, right? What's the green? While we're at it what are the others? Attached thumbnail(s) |
jcd914 |
Nov 16 2009, 06:32 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Someone put brake line tube in. Most SS, and all copper is non-magnetic. Brake line is usually plated with a wierd green coating. Interesting. Maybe I'm looking at the wrong lines in the rear of the tunnel. I've color keyed the picture of the tunnel. The pink is the fuel line, right? What's the green? While we're at it what are the others? Pink are the fuel lines Large Green is Cutch cable tube Small Green is Throttle cable tube Blue and Orange are Heater flap cables. Jim |
dkos |
Nov 17 2009, 11:37 AM
I mistook the green tubes (clutch and throttle) for the fuel lines. I reached in there again last night and found the plastic lines. They were really tucked in there against the side of the tunnel. I guess I have the original fuel lines after all. Can you just replace the plastic part of the old fuel lines?
SirAndy |
Nov 17 2009, 11:41 AM
Resident German Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can you just replace the plastic part of the old fuel lines? I replaced mine with Chris's Stainless Steel fuel lines. Clean, simple, quick. Great product ... http://www.tangerineracing.com/stainlessFuelLines.htm (IMG:style_emoticons/default/shades.gif) Andy |
dkos |
Nov 17 2009, 12:45 PM
QUOTE I replaced mine with Chris's Stainless Steel fuel lines. Clean, simple, quick. Great product ... http://www.tangerineracing.com/stainlessFuelLines.htm (IMG:style_emoticons/default/shades.gif) Andy I know I should just get Chris's SS fuel lines...and I probably will. It's just that I'm broke and trying to save $$$. I still need to address my brakes and get a new windshield. I just want to make this thing safe and be able to drive it again. This car will never be a show car or a racer. Other than a joy ride on a nice weekend it'll just sit in the garage. Would it be so bad to just run high pressure fuel line right from the gas tank thru the tunnel to wherever it goes next...fuel filter...fuel pump? |
Lo-Fi Version | Time is now: 16th June 2024 - 09:18 AM |
