> what oil pump would you use
wayne1234
post Nov 20 2009, 12:53 AM
Well I'm going to order some parts today to put the engine back together, I basically have a stock 2.0 with a mild cam, and carbs, nothing special, should I just get a new factory oil pump or something else, I'M not gonna race it or any thing crazy, so Im thinking a stock setup would be fine where is the best place to get one? or am I crazy not to get "Blank set up" . Thanks and again recommend a vendor.
sww914
post Nov 20 2009, 01:03 AM
My experience with the aftermarket oil pumps is that their internal machining leaves a lot to be desired. I use the best used pump that I can scavenge out of my piles of parts. If it's in the budget I go for new OEM.
type47
post Nov 20 2009, 06:44 AM
Viermeister
QUOTE(sww914 @ Nov 19 2009, 11:03 PM) *
How do you test the pump to see if it's still usable? (I have some used pumps that I'd like to know if they're still good)
wayne1234   what oil pump would you use   Nov 20 2009, 12:53 AM
sww914   My experience with the aftermarket oil pumps is th...   Nov 20 2009, 01:03 AM
type47   I use the best used pump that I can scavenge out...   Nov 20 2009, 06:44 AM
jmill   There was a big thread about this. I believe that...   Nov 20 2009, 07:53 AM
tat2dphreak   I used a shadak 30mm pump. jake said the shadak...   Nov 20 2009, 08:11 AM
Mark Henry   Small engine so a shadak 26mm pump is all you need...   Nov 20 2009, 08:40 AM
wayne1234   how do you know if they are any good? someone said...   Nov 20 2009, 11:57 AM
ME733   :popcorn: I have used MELLING oil pumps with great...   Nov 20 2009, 04:55 PM
Drums66   :popcorn: I have used MELLING oil pumps with grea...   Nov 21 2009, 04:01 PM
Jake Raby   I'll post some pics of a Melling pump on Monda...   Nov 21 2009, 04:41 PM
StratPlayer   I'm running a melling in my new engine build. ...   Nov 22 2009, 03:14 PM
Cap'n Krusty   And, besides all those features, you get, free of ...   Nov 22 2009, 04:12 PM
Jake Raby   In testing now.. Available in both + and - .002 si...   Nov 22 2009, 06:12 PM
StratPlayer   The melling that I have on my engine has no leaks ...   Nov 22 2009, 07:50 PM
Jake Raby   The melling that I have on my engine has no leaks...   Nov 22 2009, 09:07 PM
Jake Raby   Here is your modern day Melling pump. This one...   Nov 23 2009, 09:33 AM
craig downs   I was using a Schadek oil pump and got scared of t...   Nov 24 2009, 12:56 AM
Jake Raby   Here is another...   Nov 24 2009, 09:16 AM
ME733   :popcorn: ....Very Intresting...I wonder what caus...   Nov 24 2009, 10:46 AM
StratPlayer   How many out there are running melling pumps and h...   Nov 24 2009, 10:52 AM
Drums66   How many out there are running melling pumps and ...   Nov 24 2009, 01:18 PM
jhadler   Have/had a Melling. Not sure if it's doing me ...   Nov 24 2009, 01:16 PM
Jake Raby   Like most everything else the quality of the Melli...   Nov 24 2009, 05:04 PM
jhadler   Perhaps my Melling is still in the "good...   Nov 24 2009, 05:08 PM
ME733   :popcorn: TO ..J Hadler , Craig Downs, and other...   Nov 25 2009, 06:27 AM
- Lo-Fi Version Time is now: 1st April 2026 - 11:14 PM
