> what oil pump would you use
wayne1234
post Nov 20 2009, 12:53 AM
Well I'm going to order some parts today to put the engine back together, I basically have a stock 2.0 with a mild cam, and carbs, nothing special, should I just get a new factory oil pump or something else, I'M not gonna race it or any thing crazy, so Im thinking a stock setup would be fine where is the best place to get one? or am I crazy not to get "Blank set up" . Thanks and again recommend a vendor.
ME733
post Nov 20 2009, 04:55 PM
(IMG:style_emoticons/default/popcorn[1].gif) I have used MELLING oil pumps with great success., The housing is cast iron and will maintain the center to center distances of the pump gears much better than aluminum. The port openings into and out of the pump can be blended with porting tools, opened and smoothed with great success. The gears are extremely interferance press fit, so the "spinning shaft "problem does not exist.(never heard of one doing this)...the back housing, against the cam gear, is solid...no extra nuts... to assemble housing ...in the way..(or to screw with) SOME people will disagree, because the OIL PUMP housing is cast IRON, and the Engine BLOCK install area is ALUMINUM. Maybe it will be 190 /220 degrees. the expansion differences (if much)(at all).and the worry factor ?...Can be ELIMINATED by Radusing the inner /outer mating surfaces at the crankcase and installing a ..O..ring...at the pickup tube entry. now you got two seals, the oem one and the one you will creatate. Big deal. the oil pump is a critical component of the engine , and should be cleaned, inspected, assembled, "feel Tested" for binding and smoothness of rotation. I'm talking about "BLUEPRINTING " the damn pump guys. Its worth the extra trouble to know your oil pump is going to work properly perfectly. And...MELLING has more experience, and manufactures more oil pumps than all the rest of the "trick "oil pump companies combined and has been doing so for Years. :the end. (IMG:style_emoticons/default/popcorn[1].gif)
wayne1234   what oil pump would you use   Nov 20 2009, 12:53 AM
sww914   My experience with the aftermarket oil pumps is th...   Nov 20 2009, 01:03 AM
type47   I use the best used pump that I can scavenge out...   Nov 20 2009, 06:44 AM
jmill   There was a big thread about this. I believe that...   Nov 20 2009, 07:53 AM
tat2dphreak   I used a shadak 30mm pump. jake said the shadak...   Nov 20 2009, 08:11 AM
Mark Henry   Small engine so a shadak 26mm pump is all you need...   Nov 20 2009, 08:40 AM
wayne1234   how do you know if they are any good? someone said...   Nov 20 2009, 11:57 AM
ME733   :popcorn: I have used MELLING oil pumps with great...   Nov 20 2009, 04:55 PM
Drums66   :popcorn: I have used MELLING oil pumps with grea...   Nov 21 2009, 04:01 PM
Jake Raby   I'll post some pics of a Melling pump on Monda...   Nov 21 2009, 04:41 PM
StratPlayer   I'm running a melling in my new engine build. ...   Nov 22 2009, 03:14 PM
Cap'n Krusty   And, besides all those features, you get, free of ...   Nov 22 2009, 04:12 PM
Jake Raby   In testing now.. Available in both + and - .002 si...   Nov 22 2009, 06:12 PM
StratPlayer   The melling that I have on my engine has no leaks ...   Nov 22 2009, 07:50 PM
Jake Raby   The melling that I have on my engine has no leaks...   Nov 22 2009, 09:07 PM
Jake Raby   Here is your modern day Melling pump. This one...   Nov 23 2009, 09:33 AM
craig downs   I was using a Schadek oil pump and got scared of t...   Nov 24 2009, 12:56 AM
Jake Raby   Here is another...   Nov 24 2009, 09:16 AM
ME733   :popcorn: ....Very Intresting...I wonder what caus...   Nov 24 2009, 10:46 AM
StratPlayer   How many out there are running melling pumps and h...   Nov 24 2009, 10:52 AM
Drums66   How many out there are running melling pumps and ...   Nov 24 2009, 01:18 PM
jhadler   Have/had a Melling. Not sure if it's doing me ...   Nov 24 2009, 01:16 PM
Jake Raby   Like most everything else the quality of the Melli...   Nov 24 2009, 05:04 PM
jhadler   Perhaps my Melling is still in the "good...   Nov 24 2009, 05:08 PM
ME733   :popcorn: TO ..J Hadler , Craig Downs, and other...   Nov 25 2009, 06:27 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:31 AM
