> D-Jet troubleshooting
saigon71
post Nov 13 2009, 03:36 PM
Could use some ideas…
Background: Car sat idle in a garage for six years - 37K miles. Engine was free. 2.0 factory d-jet. I adjusted the valves, installed a new fuel filter, changed the oil & put some gas in it. It fired up but had a very high idle.
Since then, I have done the following:
-New plugs & wires
-New distributor cap, points & condenser (rotor was clean)
-New air filter
-New alternator & voltage regulator - tested good
-All new vacuum lines from AA
-New intake runner gaskets and manifold to head gaskets
-Tested all FI components except the brain. Replaced AAR and MPS with good used
ones, bench tested each before installation. MPS holds 20 in HG and electrical tests
were within limits. Replacement parts are compatible based on this site:
http://members.rennlist.com/pbanders/djetp...tm#troubleshoot
-Tested fuel pressure - dead on factory spec of 2.0 bar
-Dwell well within specs
-Set timing dead on at 27 degrees BTDC with distributor lines plugged and disty at
full advance
- TPS set according to the picture I found on this site
- New plenum to intake runner gasket
- New cold start valve gasket
- Tested PCV Valve
- Plenum inspected – no holes found
- Throttle body removed & thoroughly cleaned
At all ambient temps tested (50-70 degrees F), the car fires right up but stalls almost immediately…this happens twice. Tapping the throttle does not help. On the third start, the car stays running and idle varies between about 800-1200 RPM. After about 10 minutes, it settles in at about 950RPM or so. Besides this, the engine runs great, has plenty of power and pulls hard in all five gears. Is this as good as it gets or am I missing something. Thanks in advance.
Bob
detoxcowboy
post Nov 24 2009, 06:50 PM
Region Association: Africa
Check Your timming? Oscillation w/ high idle can mean you have a leak where you do not expect it, I do not know what is in Auto Atlanta's vacummn line kit but...
Idle oscillates and/or idle is too high and cannot be adjusted down to 1000 rpm with the air bleed screw Vacuum leak
Timing over-advanced
Check the following areas for a vacuum leak:
1. Intake runner-to-head gasket/spacer
2. Injector seals
3. Intake runner boots
4. Air plenum (e.g. cracks or rust holes)
5. Throttle body gasket
6. Throttle body shaft (worn body or shaft)
7. Distributor vacuum adv/ret cell
8. Auxiliary air regulator (stuck open or leaky)
9. Deceleration valve
10. Manifold pressure sensor
11. Vacuum hose cracks
12. Cold-start valve gasket to plenum
saigon71
post Nov 24 2009, 07:15 PM
QUOTE(detoxcowboy @ Nov 24 2009, 07:50 PM) *
2. Injector seals
Timing is spot on at 27 degrees BTDC. AA's vacuum line kit included every piece of vacuum line needed to replace all lines.
1. New
2. New
3. New
4. Inspected, no cracks or rust holes found.
5. New
6. Inspected, no excessive play
7. HOW DO I TEST THIS?
8. Replaced with bench tested used unit
9. Tested, will re-test
10. Replaced with bench tested used unit
11. All new vacuum lines & elbows installed
12. New gasket installed
It looks like the only thing I missed on this list is: Distributor vacuum adv/ret cell - how do I test this.
Thanks
saigon71   D-Jet troubleshooting   Nov 13 2009, 03:36 PM
r_towle   AAR Valve... What have you dont with that Cold sta...   Nov 13 2009, 04:50 PM
saigon71   AAR Valve... What have you dont with that Cold st...   Nov 13 2009, 10:24 PM
Bruce Allert   :agree: wut he said! I had the same problem...   Nov 13 2009, 05:55 PM
jsayre914   i had a problem with the idle going back to where ...   Nov 13 2009, 06:04 PM
saigon71   i had a problem with the idle going back to where...   Nov 13 2009, 10:31 PM
Bruce Allert   I removed the decel & it was more bedda! ...   Nov 13 2009, 06:41 PM
r_towle   Here is a test. Turn key on to run...turn off. Do...   Nov 13 2009, 10:27 PM
saigon71   Here is a test. Turn key on to run...turn off. D...   Nov 13 2009, 10:35 PM
saigon71   Here is a test. Turn key on to run...turn off. D...   Nov 24 2009, 06:26 PM
Bruce Allert   Check the psi by putting a guage in line going to ...   Nov 14 2009, 12:15 AM
detoxcowboy   Check Your timming? Oscillation w/ high idle can m...   Nov 24 2009, 06:50 PM
saigon71   Check Your timming? Oscillation w/ high idle can ...   Nov 24 2009, 07:15 PM
detoxcowboy   Check Your timming? Oscillation w/ high idle can...   Nov 24 2009, 08:17 PM
r_towle   Its a vacuum canister. Remove the one or two vacuu...   Nov 24 2009, 07:21 PM
saigon71   [quote name='r_towle' date='Nov 24 200...   Nov 24 2009, 07:56 PM
r_towle   As soon as starter is not cranking the engine, ...   Nov 24 2009, 08:09 PM
detoxcowboy   How is it supposed to idle, anyway? (copied from t...   Nov 24 2009, 08:38 PM
saigon71   How is it supposed to idle, anyway? (copied from ...   Nov 29 2009, 09:53 PM
SLITS   In the D-Jet system, the operating pressure is abo...   Nov 24 2009, 10:07 PM
saigon71   In the D-Jet system, the operating pressure is ab...   Nov 29 2009, 09:39 PM
- Lo-Fi Version Time is now: 11th July 2025 - 07:13 AM
