Will a 901 trans hold up to a 3.2L engine |
Bill Smith |
Nov 26 2009, 04:14 PM
Member Group: Members Posts: 169 Joined: 2-May 06 From: Keyser, WV Member No.: 5,964 |
I recently had a transmission go out on my 914 after 3 years at a DE. My car has a stock 3.2 with a Euro chip and custom Exhaust. I lost 4th gear. Had the usual problem with getting into first. I was also running a Quaiffe Diff. When it happened, I only did one lap due to an unusual noise and then called it a weekend before I tore up the quaiffe. When I got it apart the only two problems were that 3 teeth were missing on one of the 4th gears and the double ball bearing was broken but I may have done this getting the trans apart. IN hind sight, I heel and toe very good but most times dont match rpm versus speed on down shifts which on the tracks we run at is usually 3rd not 4th.
I also have a friend driving the exact set up as I am driving that also has 3 years on his 3.2 with a 901 with no problems. Several guys at the track said I was wasting my time and money on the 901 and that I should spend the $5000-7000 to go to a 915 or even better a G50. What do you guys think - Am I wasting my time? |
marks914 |
Nov 29 2009, 01:22 PM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Been running well over 400HP through my 914 trans for 7 years now. No problems.
Mark |
Lo-Fi Version | Time is now: 11th June 2024 - 08:08 AM |
