Cleaning a 901 Case ? |
whatabout1 |
Dec 1 2009, 04:43 PM
Toys in Red Group: Members Posts: 403 Joined: 6-March 06 From: Charlotte, NC Member No.: 5,676 Region Association: None |
I just found a 901 side shift w/ short gears and quaffe !!!
It was sitting in the basement of a house that burnt. When I opened it the inside is coated with gear lube and looks fine. The plastic covers are cracked but not melted. But the outside of the case is covered with white corrosion. Just on the surface. (not deep like some of the mag wheels I've had) So how to clean ? I have a bag of walnut shells ..... |
Dr Evil |
Dec 2 2009, 11:58 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
RE your revision:
I am pretty sure it was not the HEAT that caused the oxidation. Probably was the water and agents used to put the fire out, no? Of course anyone with any core should replace the seals. As for hot enough to gel the oil in the case, he said it looks good. Sure, it should be considered for a rebuild, but not due to heat. |
Lo-Fi Version | Time is now: 11th June 2024 - 11:00 PM |
