x98boardwell |
Member ![]() ![]() Group: Members Posts: 62 Joined: 14-October 09 From: Central Valley, CA Member No.: 10,935 Region Association: None ![]() |
While I was putting the new condensor in my distributor I realized the green wire was just shorter than the stock unit I was taking out. I had to bend the flange on the condensor so that it would sit better on the distributor. When I did this I accidentally pushed in the metal a little bit on the condensor.
Will this ruin the condensor? Is anythign spinning inside? It may have been dented in 1mm or so at the most. I can take a picture if needed. Thanks in advance for the help. Bryan |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
An auto ignition condenser is essentially a capacitor. If it's dented it could change the properties of the capacitor. Depends on where the physical components (the plates more likely) of the cap are in relation to the case of the condenser. I kind of doubt though that what you've described is going to effect it enough to worry about. I'd use it anyway. If it works it works. If it doesn't, replace it.
http://en.wikipedia.org/wiki/Capacitor |
Lo-Fi Version | Time is now: 1st July 2025 - 09:41 AM |
