x98boardwell |
Member ![]() ![]() Group: Members Posts: 62 Joined: 14-October 09 From: Central Valley, CA Member No.: 10,935 Region Association: None ![]() |
While I was putting the new condensor in my distributor I realized the green wire was just shorter than the stock unit I was taking out. I had to bend the flange on the condensor so that it would sit better on the distributor. When I did this I accidentally pushed in the metal a little bit on the condensor.
Will this ruin the condensor? Is anythign spinning inside? It may have been dented in 1mm or so at the most. I can take a picture if needed. Thanks in advance for the help. Bryan |
Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
Cars can run with a damaged (partially grounding) condenser. If you hook up your car to a scope you will quickly see if it's working at 100% or not. When viewing the scope you see the voltage "spike" (spark plug firing), immediately after that is the quickly tapering "squiggles" which are the "back voltage" or CEMF (counter electromotive force) induced by the high voltage (secondary) field inducing voltage back to the primary, this would continue longer, save for the condenser.
It is the condenser which is lowering/absorbing the CEMF to the point of zero voltage before the points open and fire the next spark plug. If there is still high voltage at the time the points close, a higher voltage will be seen at the points and they will wear prematurely. The job of the condenser is to absorb and dissipate the CEMF to give longer life to the points. If a condenser begins to fail your points system will degrade much more quickly. Condensers only work when grounded, BTW. While a condenser does absorb CEMF, it purpose is not to store voltage per se, more to dissipate CEMF via grounding. Note any schematic. When in doubt, bite the bullet. Good luck. |
Lo-Fi Version | Time is now: 1st July 2025 - 10:48 AM |
