> Question: If I dented Condensor housing... is it bad? What's insi
x98boardwell
post Dec 6 2009, 08:58 AM
While I was putting the new condensor in my distributor I realized the green wire was just shorter than the stock unit I was taking out. I had to bend the flange on the condensor so that it would sit better on the distributor. When I did this I accidentally pushed in the metal a little bit on the condensor.
Will this ruin the condensor? Is anythign spinning inside? It may have been dented in 1mm or so at the most. I can take a picture if needed.
Thanks in advance for the help.
Bryan
Gint
post Dec 6 2009, 09:13 AM
Mike Ginter
An auto ignition condenser is essentially a capacitor. If it's dented it could change the properties of the capacitor. Depends on where the physical components (the plates more likely) of the cap are in relation to the case of the condenser. I kind of doubt though that what you've described is going to effect it enough to worry about. I'd use it anyway. If it works it works. If it doesn't, replace it.
http://en.wikipedia.org/wiki/Capacitor
zonedoubt
post Dec 6 2009, 11:29 AM
Canadian Member
QUOTE(Gint @ Dec 6 2009, 07:13 AM) *
The "can" style of capacitors are usually a rolled up metal foil/dielectric sandwich. I don't think a dent is going to affect the operation. They're in a metal can so they can take some abuse.
But a replacement is cheap piece of mind.
- Lo-Fi Version Time is now: 1st July 2025 - 11:16 AM
